Glare Free Headlights - Use Case
If everyone had glare free lighting then we wouldn't get high beamed all the time by inattentive drivers and people with misaligned headlights.
HornetRaider
Abe
DFW
2023 Lariat ER
Yeah it’s very noticeable to me anyway but I’m a nerd and look at stuff like that. If your little highbeam telltail on the cluster is green then glare free should be working. If it’s white then you just have normal auto high beams.
That’s the strange part. It is green and the toggle is showing under vehicle settings.
Deleted member 19221
Guest
Is it fairly easy to enable? I've never used FORscan, but might be willing to give it a try to get that feature enabled. I live in a rural area and I think it would be a good thing to have.
bc1
McPherson, KS
For what it's worth I've been using glare free for a few days now on a dark state highway but also has a few mile section of oil field gas plants and underground propane storage wells which is all lit up dead ahead as on the horizon like downtown as I navigate around curves through all this.
With the green auto icon lit up it seems like the automatic dimming goes on and off and never shows the blue brights icon. The glare free does show the shoulders more but doesn't illuminate as far down the highway itself and the signs aren't as bright. If I pull back on the stalk and hold it it does go into the original brights with the blue icon and illuminates the signs an looks further down the highway. Pushing forward on the stalk can also shift it to brights and out of automatic and the next push will dim them with another push getting me back to automatic lights again. I can also turn the dial down below on the dash to get to regular lights with manual control of the lights with a brights and dims option.
So the good side of glare free is I can see the ditches better for deer but I can't see as far straight down the the road for let's say deer, coons, skunks, possums, etc. in the road. What I want to avoid for sure are the deer standing in the road but I see a lot of vehicle parts and stuff the fell out of pickups and trailers laying in the road that are hard and something I don't want to run over but sometimes don't get enough advance notice to see. I have seen a number of rear bumper covers that have fallen off of cars laying in the road which at least aren't hard but they can scratch and dent the paint on the sides or cut a tire. Also have a lot of lumber, trash, and tree limbs laying in the road so that is also a big concern besides deer in the ditch.
The amount of traffic varies with how late in the evening it is but I believe I can start in glare free, forward move the stalk to go to brights in non-glare free but when traffic does appear ahead I can do a double move forward to go to dims and then to glare free.
So this is still new to me but just wondering if this is normal operation and if there are any other hints I need to know? Thanks.
21st Century Truck
Martin
Yes, with some patience and with a meticulous approach there's nothing really hard about it. And the gain is absolutely worth it, in many driving environments.
molsonmatt
Matthew
New Jersey
2024 Lightning Lariat
I don’t have FOREscan nor am I well versed in or want to be. Glare free headlights is the one mod I would love to do. Is there a way to modify my truck by bringing it somewhere to have someone do it? Is that a service that’s offered by anyone? Anyone in NJ want to make a couple bucks?
21st Century Truck
Martin
Sure and it would be helpful if You add Your general location in the avatar block for people in Your area to respond to Your post.
I've helped several fellow Lightning drivers turn this on... when I and they knew we were relatively close to each other..
21st Century Truck
Martin
Ah I now see New jersey in Your post. I still recommend adding something in Your avatar block.
carys98
Cary
Raleigh, NC
2023 Lightning Lariat SR
Retired EE
I think I posted this earlier but I had the green icon and the toggle for several months and my glare free was not working. I had missed one change and had a DTC in the HCM. I went back through every change until I found the error and now they are working perfectly.
I think there was an early post that had the error in it and that is what I used initially. Check for any DTCs and be sure you are using the settings at the top of the Forscan Version 2 thread and verify that you didn’t miss any.
HornetRaider
Abe
DFW
2023 Lariat ER
I pulled codes and do have a fault in the HCM. Was yours similar to what I’m seeing?
Ford F-150 Lightning Glare Free Headlights - Use Case IMG_5055
carys98
Cary
Raleigh, NC
Retired EE
I don’t remember the code but it was listed as a checksum error. The HSM settings are a little different from the others. Every line in the as-built has a checksum, it’s the two dashes on the end that Forscan will calculate for you. In the HCM section the line 734-11-01 is a separate checksum for the whole module. I think I had missed the last 1 on the 734-03-02 line but I’m not certain.
APIM 7D0-09-01 x1xx xxxx xx--
APIM 7D0-09-03 xxCx xxxx xx--
IPMA 706-01-01 xxxx xxx9 xx--
SCCM 724-04-01 xxx4 xxxx xx--
IPC 720-01-01 xx8x xxxx xx--
IPC 720-10-01 xxxx xxx3 xx--
HCM 734-01-02 xxxx x2xx xx-
HCM 734-03-02 xxxx xxx1 x1--
HCM 734-11-01 0735 89
bc1
McPherson, KS
And here are my codes when it was all done.
APIM 7D0-09-01 6117 4A28 FEC9
APIM 7D0-09-03 04C0 0004 07B2
IPMA 706-01-01 8E50 A059 AE94
SCCM 724-04-01 2844 0000 9C
IPC 720-01-01 0F8A 1064 D006
IPC 720-10-01 1B08 0023 007E
HCM 734-01-02 0001 0200 0041
HCM 734-03-02 111E 1801 0189
21st Century Truck
Martin
The green telltale on the IPC, when it is displayed, only shows that the IPC module code was chaged.
For the glare free function to work ALL of the six modules involved have to have their appropriate code lines changed.
These modules interact and the IPC module only controls the IPC display.
I hope this is useful info.
bc1
McPherson, KS
Has anyone here been in another vehicle while their wife or someone has driven their lightning at night on a highway just to see how the glare free looks both oncoming and following and going from brights to dims, etc.? Just wondering what the experience is. Perhaps time for an experiment.
