Driving Score - Home Assistant
BriyGuyUSA
Glyn
Atlanta, GA
2023 Lariat ER 511A Antimatter Blue
IT Stuff
I'm using the Fordpass Home Assistant Integration from here: https://github.com/marq24/ha-fordpass and have built out a pretty nice dashboard. One of the things that you can get from this, is an Acceleration, Deceleration, Speed and Driving score. Seems to be out of 100%. Anyone know anything about these scores and how they are calculated? Metrics shown are not great in this example as it would appear I accidentally remotely turned on my climate for 5 minutes yesterday which seems to have scrubbed the last trip information.
Ford F-150 Lightning Driving Score - Home Assistant 1767811625814-rf
I don't know how they are calculated, but Ford has (had?) agreements with at least one Insurance company that they could be shared. There are options to turn this connection in the GUI. This was so you didn't need the Dongle connected to your smartphone for this kind of tracking.
I'm guessing the calculations were at least shared with or shown to hold merit for driver tracking at a minimum.
You folks in Georgia spell Efficiency weird LOL.
I have the same HA integration - will have to look into it.
Ford F-150 Lightning Driving Score - Home Assistant 1767829599360-4o
BriyGuyUSA
BriyGuyUSA
Glyn
Atlanta, GA
IT Stuff
You know, I would look at that every time I opened the dashboard and I thought "That does not look right" lol
  • Haha
JvdMaat
W. Mass
Where are you finding that data? Are you using the _lastenergyconsumed sensor, and the TripDistanceTraveled attribute under that and using a template to get the mi/kWh?
I'm not seeing this raw data (nor the Ifficiency ;) )
BriyGuyUSA
BriyGuyUSA
Glyn
Atlanta, GA
IT Stuff
These are my cards:
Ford F-150 Lightning Driving Score - Home Assistant 1767888948805-2s
Ford F-150 Lightning Driving Score - Home Assistant 1767888979351-su
Ford F-150 Lightning Driving Score - Home Assistant 1767889012876-us
Ford F-150 Lightning Driving Score - Home Assistant 1767889037292-jf
Ford F-150 Lightning Driving Score - Home Assistant 1767889068303-ov
Ford F-150 Lightning Driving Score - Home Assistant 1767889089378-0z
Ford F-150 Lightning Driving Score - Home Assistant 1767889109698-dv
Ford F-150 Lightning Driving Score - Home Assistant 1767889136147-x
BriyGuyUSA
BriyGuyUSA
Glyn
Atlanta, GA
IT Stuff
Whole dashboard (with spelling correction) if anyone is interested. Cant find the attribute for the wiper fluid status - has to be in there somewhere as it's shown the app.
Ford F-150 Lightning Driving Score - Home Assistant 1767889273529-cm
JvdMaat
W. Mass
That is attribute "Lowwasherfluid 600E19" under Indicators.
JvdMaat
W. Mass
I'm having trouble with the data on our side. Here's some of the elveh attributes from my wife's trip to work this morning:
Code:
BatteryAmperage             0.08
BatteryVoltage              361
BatteryCharge              62
BatteryActualCharge       54.96
BatteryPerformanceStatus     NORMAL
BatteryEnergyRemaining          61.7
MaximumBatteryCapacity          124.7
MaximumBatteryRange          275.58
TripRangeRegenerated         1.99
TripDrivingScore              99.8
TripSpeedScore                  100
BatteryStateOfChargeTargetDisplay     100
TripDecelerationScore             100
TripAccelerationScore             100
TripElectricalEfficiency           0
TripAmbientTemp                  23.45
TripOutsideAirAmbientTemp          23.45
TripDuration                       0:27:18
TripCabinTemp                        24.8
TripEnergyConsumed                   3.57
TripDistanceTraveled                12.43
TripEfficiency                   3.48
State of charge went from 69% to 62% for this trip. So 7% of the battery was used (ER, so out of 131kWh), which should be around 9kWh. Based on our outdoor temp (freezing), I would expect a trip score of about 1.5mi/kWh or less. (12.43 mi/9.17 kWh=1.36, which is probably what the actual mi/kWh was)
But the TripEnergyConsumed is 3.57 kWh. Making for 3.48mi/kWh efficiency.
I'm sure it's an issue because of the cold. But the numbers just don't add up. There's nothing to justify that.
I'm also curious about the MaximumBatterCapacity; 124.7(kWh?) is about 95%. What does this attribute mean? (Or does that just mean in this cold, the battery can only be charged to 124kWh.)
Someone in a warmer climate have better data?
Lightning-E
Wisconsin
Developer
Anyone using the HA integration receive an email from Ford yet? Last time I tried using their API for an integration they got real pissy and threatened to basically blacklist my vehicle. Granted this was with my Mach-E but still.
BriyGuyUSA
BriyGuyUSA
Glyn
Atlanta, GA
IT Stuff
The newer integration uses pull which should cut down on the API calls. Also, setup an account specifically for this integration so if they do shut it down, it wont impact your every-day account.
BriyGuyUSA
BriyGuyUSA
Glyn
Atlanta, GA
IT Stuff
Code:
BatteryVoltage              361
BatteryCharge              62
TripSpeedScore                  100
TripCabinTemp                        24.8
TripEfficiency                   3.48
I'm not sure how accurate any of these numbers are really, and nothing is documented either so we're just basically guessing as to what each mean.
Example, apparently my 220v charger is charging at 370 volts:
Ford F-150 Lightning Driving Score - Home Assistant 1768149111826-oo
That looks like it is reporting the DC side of the onboard charger - what it is feeding the battery. 370 volts at 28.7 amps = 10.6 kW.
If your EVSE is at 240 volts I'm guessing its amps is around 48A including the 10% conversion losses.
BriyGuyUSA
BriyGuyUSA
Glyn
Atlanta, GA
IT Stuff
Yeah, that makes more sense - it's on its own 60 amp circuit.
