chriserx
That was always going to be likely in any event, there are a multitude of reasons why they would want to limit access to specific countries. I do wonder if your account is being blocked by bank location or by OS configuration though. The email does state that you attempted to use VPN. You said that you attempted to use the service in allowed countries, was that before or after the VPN usage, assuming you did attempt to do so?I would like to further clarify the situation based on the official email from IOEUFSI, which I have attached for reference.
In that email, it is clearly stated that the use of a VPN is not permitted. The FDRS system is able to detect VPN usage automatically, and once detected, the account or access is immediately blocked.
However, I would like to emphasize that this issue is not related only to VPN usage.
I have also attempted to access FDRS from other European countries that are officially listed as supported on the FDRS/MotorcraftService website, without using any VPN at all. Despite this, the result is the same ā the system still blocks access immediately. This confirms that this is a broader European/regional issue, not a user-side configuration problem.
Additionally, I have experienced cases where I:
- Purchased an official FDRS subscription
- Attempted to use it without any VPN
- Still had the access blocked immediately
In such cases, the company selling the FDRS subscription did issue a refund, acknowledging that the system blocked access even without VPN usage.
However, in cases where a VPN was used, the policy is different:
- The system blocks access automatically
- No refund is provided, regardless of the outcome
This situation leaves users in regions like mine without a viable solution, as Ford Europe does not appear to actively address or resolve this issue, despite FDRS subscriptions being officially sold for Europe.
