Odd AC Charging behaviour
chriserx
Louisiana
if that's the case, then it may be the battery. i'll have to get someone to check out its status
It's extremely tiny with an odd, harsh charging profile, your profile doesn't list the year truck but the older ones also had a 12v BMS issue.
Yes, sadly, the way the Ford BMS for the 12v battery works is not designed for longevity:
It does not top it off all the way to 100% on a regular basis;
when it charges the 12v it does not limit the current to a healthy level apparently which ends up damaging the battery over time (heat);
it allows the 12v battery SOC to get low which results in sulfates building up over time.
Here's some more info fyi:
I keep my 12v battery on a trickle charger/battery maintainer with an AGM mode to avoid premature death (its, not mine) and to ensure OTAs get installed..
Deep discharge, which the lightning algorithm allows, is not good for longevity of these batteries, and the high charging currents seen when the battery is low, are another bad feature of the lightning system of 12v battery management.
This post form the Mach-e forum goes into depth about these 12v AGM batteries:
https://www.macheforum.com/site/threads/how-to-recondition-service-your-12v-battery.11069/
If the details about how AGM battery charging progresses are accurate, the truck will not, on it's own, top off the battery in many cases because of the time it takes. That makes a trickle charger even more important for longevity since it can be on the 12v battery for many hours at a time charging even when the truck HV is not.
And this one about the different ways to charge up the battery to get OTAs:
https://www.macheforum.com/site/threads/how-to-get-failed-otas-to-install.29749/
Also several threads here about putting trickle chargers on the battery and how to make it easier by adding a trickle charger wire:
https://www.f150lightningforum.com/forum/threads/charging-12v-battery.16979/
This is what I did (a fused SAE cord to the charge port from the battery):
Ford F-150 Lightning Odd AC Charging behaviour 0-My Lightning-IIMG_6004-SAE at charge port
truthlesshunter
'22 Lightning lariat ER-Lucid Air GT-718S
it's a 2022 so definitely would be in the affected years
truthlesshunter
super helpful...thanks. i'll have to keep this in mind as a possibility and safeguard
ZSC100
Zach
Tulsa, OK
Electrical Engineer
Get an OBDLink adapter and CarScanner immediately. You can watch your 12V charging system and so many other things live and probably diagnose the issue yourself without even reading DTC's but also Read the DTC's and clear them with the same troubleshooting logic and if it's the truck you will know quickly.
I suspect it's something with your EVSEs, bad contacts somewhere, loose wires, etc. If it's anything outside the truck you likely won't be able to diagnose it with the truck. Let us know once you get CarScanner going and we'll tell you what PIDs to look at while attempting to charge.
Adventureboy
As mentioned, dealer didn't want to take it in because it started working again...
They can check the codes remotely. You don't even need to take the truck in for them to identify a problem. When I call my dealer about anything, that is the first thing my service advisor does and we talk from that point forward.
Adventureboy
In your case, if both EVSEs identified a Ground Fault (leakage to ground), it can be caused by the truck or by a wiring fault to the EVSE (I've seen errors caused on both sides with my truck). It appears to be the truck in your case since it throws the fault when you plug in and your other EV is fine. Intermittent faults like this are a b*tch to find so I understand the dealer's hesitation.
The 12V system can give you grief, but unless you've seen other symptoms, I doubt that is the issue. I certainly wouldn't rule it out. A quick voltage check on the 12v when you get the error would rule it out, but if the truck starts fine, it likely isn't that.
Reactions: chl
bc1
McPherson, KS
Just wondering how many stealership service advisors will get on the computer and check your codes without charging you for a service call or you actually being there for a warranty work or service call where they had you sign an authorization that may bind you to pay for something not covered by ford warranty? Somehow I don't think I'd have any luck if I made a cold call to one who didn't know me from Adam even if he could look it up and see someone with my name bot the truck there.
Adventureboy
I consider myself very lucky on this front. I've always known the codes it is throwing before I call. That way, I'm calling from a somewhat knowledgeable position - and I have a good relationship with the service rep ;-)
In your case, if both EVSEs identified a Ground Fault (leakage to ground), it can be caused by the truck or by a wiring fault to the EVSE (I've seen errors caused on both sides with my truck). It appears to be the truck in your case since it throws the fault when you plug in and your other EVSE is fine. Intermittent faults like this are a b*tch to find so I understand the dealer's hesitation.
Yea, I agree, I overlooked the ground fault being id'd by the EVSE's.
So most likely a problem in the charge port or it's wiring.
Might check for rodent damage to the port wiring, that has been seen before!
I guess I read the op too quickly while trying to prepare for the upcoming sub-zero temps and heavy snow and ice.
Found this video about such an issue - just the basics:
Reactions: bc1
bc1
McPherson, KS
Didn't look at the video but number one that comes to mind is the blonde standing in a puddle of water while holding the charger handle. :) A lot of my problems would be solved if she was the one plugging in my charger every night. :)
  • Haha
Reactions: chl
Yes, the 'chicks' in the background all through the video are a hoot...in one case, a young woman has apparently plugged a J1772 into her vehicle and can't figure out what to do with the plug cover hanging from the EVSE cord.
The video is geared to non-technically trained people, but it covers the things everyone mentioned about the EVSE reporting a ground fault.
PS: she might be AI?
Reactions: bc1
If she is AI then I need to be AI too. 😂 They would have to be doing something with Chatgpt that I haven't figured out.
As they say...
Ford F-150 Lightning Odd AC Charging behaviour New Yorker - on the Internet nobody knows youre a dog
truthlesshunter
sorry i'm getting to you late...haven't been online for the past few days.
it's 100% NOT an EVSE or wiring issue. Both EVSEs register everything correclty upon connecting and both charge at full normal speed to other EVs. It's 100% the lightning...and now it has stopped AC charging again. And my dealership can't see the truck for two weeks...so yeah, first ford, and unless they at least fix this and cover my extra charges (since DC is literally 3-4x the price of me chargning at home...and nowhere near as convenient), this will be my last.
Should have stretched and gone for a rivian at this point. I hope my opinion changes.
