GOM Irregularities
Rtashiro
Ryan
Winnipeg, MB, Canada
I have had my truck for a little over 2 years now. Purchased brand new 2023 Lariate ER. I have a daily charge limit set to 80%. I went to leave for a short drive the other day and my SOC went down fairly quickly from 80 in the garage to 78 by the time I reversed 50 feet which I thought was odd. It continued to go down to around 75 by the time I had driven a block or two. So I started watching it carefully and the SOC started then raising back up slowly. By the time I got to my destination approximately 6 miles away the SOC was 81%. To preface the terrain is flat. Minimal to no regen was happening. on my way back in did go back down but slowly. I arrived back in my garage with 79%. Today I had another short trip and the numbers were not quite as extreme but was still odd SOC behaviour. Clearly there is something happening with the BMS but I was wondering if this needs to be calibrated and if so how? Anyone else have similar behaviour before?
What & when was your your last OTA?
Seen in the Sync screen and on Ford.COM to see the date of install.
chriserx
Louisiana
mr.Magoo
2022 Lariat ER, AMB
It's also winter in Manitoba.
The SoC in the cluster / app is what is referred to as "Displayed SoC", no one really knows (well, except Ford - and that's a maybe) how that works, but it takes a bunch of factors into account and then presents you with a SoC.
Temperature is an important factor, so if it had been sitting for a while between charging and going for your drive you might see a sudden drop, and similarly, if the day warms up quite a bit you could see a gain from that.
I'd reccomend getting an OBD dongle, it's a fairly inexpensive investment and will give you a lot of knowledge / understanding about the inner workings of your truck, you can nerd out completely like myself and @Firn , or you can just take a look at the essentials like battery temperature, state of health and module variation and sleep soundly at night knowing that everything is OK.
It's cold. It's normal.
Keep truck plugged in and use departure times for optimal accuracy.
Rtashiro
Rtashiro
Ryan
I have a dongle and paid version of car scanner. I don’t really get into the individual cell voltage stuff though.
Jiji
Rick
Finger Lakes, NY
2024 F-150 Lightning
I'll guess your battery temperature is changing. I have found that the reported Energy to Empty value changes with the battery temperature and the Distance to Empty (aka the GOM) is tied to this value.
For example, I recently charged overnight and the reported Energy to Empty at the end of the charging session was 123kWh at 53℉. Left a few hours later and the battery was cooled to 28℉ and the reported Energy to Empty was ~110kWh.
Or on a test trip made today to compare the Mach-E and Lightning, in freezing conditions I used 0.2kWh according to the Energy to Empty but in reality it was closer to 2.8kWh:
Ford F-150 Lightning GOM Irregularities 1770521975367-q6
I had to give up using the Energy to Empty data point in the Lightning and calculate my own since it adjusts the reported energy content based on the battery temperature which it warmed by just a few degrees. I believe this is why you see jumps in the Distance to Empty/Energy to Empty after the battery haas been cooled or heated.
Compare to the Mach-E doing the same trip, battery temperature didn't measurably change (it was in an unheated garage) and Energy to Empty tracks closely with my calculated value:
Ford F-150 Lightning GOM Irregularities 1770522352045-sj
Fun fact, the slope of the energy line picks up the elevation change very nicely:
Ford F-150 Lightning GOM Irregularities 1770523038154-m7
Alan168
Alan
Massachusetts
2022 Lightning Platinum, Rapid Red Metallic
I agree with Jiji. I experience the same SOC changes during our cold winters. Can't recall seeing this in the summer. But I can't reliably remember that far back anymore! :facepalm:
