dww
- First Name
- David
- Dec 10, 2023
- San Antonio, TX
- F150L, Tesla 3P, YP
After my original 12V died about a month ago I replaced it with a new OEM Ford 12V and added a cable for a 12V maintainer. I mostly drive the truck on weekends only, so it does not get a lot of daily use. With the recent cold weather I noticed that the 1a Noco was not staying green so I switched to the 5a one. Mid week I noticed it was not green but thought nothing of it (itās 5a, it will get it if it is low). Today the truck was dead and the battery was at 3.85V. I jumped it with another 12V and started the truck that then started charging it at 13.44V. I let it run for 20min and turned it off and the battery went back to 5V ish. I removed the battery and have had it on the 5a Noco for the last 8hrs. It look like it might maintain 12V. What could be causing this much drain with the truck off and why would the truck not trigger low voltage charging when it went below 10-11V? The HVB is at 70+%.
