That was it. I changed mine from xxx3 to xxx7 and now the Welcome Lighting toggle is available.
So this appears to be unique to Job 2 2025 Flash. I have a database of 100 Lightning As-Builts. Approach Lighting is enabled for 24-25 Flash except the 2025 Job 2 Flash with the 123 kWh battery (8th character of VIN is "U").
Enabled: 22-23 XLT 312A. all Lariat and Plat, 24-25 Flash w/131 kWh battery
Not enabled: All Pros and XLT 311A, 2025 Job 2 Flash.
P.S. Battery Size determination post here.
Dahveed
Salina, Kansas
2025 Ford F-150 Lightning Flash (Job 2)
Enabled: 22-23 XLT 312A. all Lariat and Plat, 24-25 Flash w/131 kWh battery (8th character of VIN is "7")
Seems like such a minor thing to not have enabled from the factory. The fob detection isn’t perfect. Occasionally it doesn’t kick the lights on, but overall it’s nice to have it enabled.
I’d like to understand the exact changes you made so I can put in post 1. Do you have the before and after Save files from Forscan you can DM me? I have the APIM but for BCM you mentioned easy mode. The Save file will show exact changes.
BrandonSRT
Fort Pierce, FL
2023 Lightning Lariat Extended Range
Hey Everyone, I just picked up my first lightning last Friday, love the truck. I just did the adaptive lights, and removed the start up seatbelt chime, and removed the double honk. Thank you for everyone over the years who put in the legwork to figure these values out!
Did anyone ever manage to figure out how to get the propulsion sound on non-platinums yet?
Welcome to the forum.
I don’t think anyone has figured out the Plat propulsion sound. My understanding is that is an interior sound for the entertainment of passengers and is not external.
There was a separate attempt to get different sounds on the external pedestrian speaker.
Kenstjohn
Ken
Tacoma, Washington
2025 F-150 Lightning Flash, 2026 Tesla Model Y Premium AWD
Retired USAF, Retired IT Managment Company Owner
Update: followed instructions here and Approach Lighting is now working, and I have the toggle in the Settings - Lighting sub-menu as well.
I found it very odd that when I review the Ford order sheet, changes to Job 2, for my 2025 everything stacks up properly (such as no phone charger, no console work platform, no step tailgate or work area liner, etc.) except the mention of "Passive Entry with Approach Detection." However, enabling the Approach Detection items in the Body Control Module, and making the change to enable Approach Lighting works perfectly.
Weird, to say the least ... but I'm happy now!! Yeah, I know this is such a minor thing ... but where we park the truck in our driveway is very dark at night and having the lighting come on as we walk up is very convenient!!
Cheers!!
Ken
jnthn98
2024 F150 Lightning Flash
Thanks everyone. This is a super helpful thread as I am new to FORScan. I am planning to get a FORScan setup soon based on this thread.
I do have a question for those who are experienced in FORScan...can I remove a specific programmed key fob using FORScan? I have a older Lightning key fob that I programmed before finding out that the '24+ Lightning switched frequencies. So that older key fob doesn't work and is taking up a key fob allowance.
According to a Ford dealership, they would need to remove all key fobs and re-programmed all the key fobs. Don't know if that is true.
BrandonSRT
Fort Pierce, FL
That is correct. It's an interior sound . The pedestrian sound outside works fine and is mandated by law. I dont mind the way that one sounds. I just really want to get the interior propulsion sound.
Dahveed
Salina, Kansas
Sorry for the slow reply. I have the before file from my BdyCM, but I didn't save an after. I'll plug into it tomorrow and save it.
But here's what I did:
OriginalNew
BdyCM
726-18-010000 0000 000101 0101 01
726-27-010001 1401 010101 1401 01
726-45-010101 F401 000101 F401 01
APIM
7D0-09-016113 4A28 FE6117 4A28 FE
  • BdyCM
    • 726-18-01
      • 0000 0000 00 to 0101 0101 01
    • 726-27-01
      • 0001 1401 00 to 0101 1401 01
    • 726-45-01
      • 0101 F401 00 to 0101 F401 01
  • APIM
    • 6113 4A28 FE to 6117 4A28 FE
Awesome thanks. I confirmed looking at six 25 Flashes (three Job 1 and three Job 2) those values are different. I'll add to post 1.
Dahveed
Salina, Kansas
No problem. :) Also, I fixed my post. Realized I left out which block it was for the APIM.
Also, of note, that block for the APIM, the 7 will depend on other settings. I was referencing the table that @carys98 posted. It was a 7 for me because I also had courtesy wipe and driver alert system enabled. It would be different for someone with a different combination of those enabled. I'm not sure what "City Safety" refers to in that block.
Ford F-150 Lightning F150 Lightning FORScan thread - Version 2 1770948021627-0v
Some credit goes to @ZSC100 as well. I was looking through their original post for adding passive entry. The detailed spreadsheet they posted helped me to find all of the settings for Welcome Lighting.
All the trucks I looked at were 3 or 7 but your point is very valid. I'll change it to "add 4" with an example, I like that style better but some folks have issues with hex math ;) . I'll make sure the other parameters also don't do double duty.
726-27-01 0001 1401 00 to 0101 1401 01
You didn't highlight but you also changed the 10th byte from 0 to 1. That byte is for auto relock. Just a typo? Or maybe you also did the relock mod?
Dahveed
Salina, Kansas
Gah, sorry. I typo'd. That byte was already a 1.
This is from my original BCM file. I had not changed anything in the BCM prior to enabling Welcome Lighting.
Ford F-150 Lightning F150 Lightning FORScan thread - Version 2 1770950282264-db
