Speed governor
4seaer
Steven
2024 ford f150 lightning
Does anybody know if it’s possible to take off the speed governor?
ZheWiz
Jack
Central NY State
Database Developer
Not so far. Closest I’ve seen is lying to the truck about tire size using Forscan. If you tell it the wheels are smaller than they really are, you’ll be going faster than the truck thinks. Of course the speedo and odometer will be off too. And I assume there’s a limit to how low you can go. I read somewhere someone did that at the track and gained a couple MPH. Don’t know details though.
theawesomegamer
Alton
Utah
2023 F150 Lightning Lariat ER w/ Max Tow
I'd have to look-- but I'd think it's probably something to do with the tires. I'm not sure through. You can definitely feel it slow down when you hit the limiter.
Ted23Lightning
Ted
23 F-150 Lightning Lariat ER, 2014 Honda VFR 750 Interceptor
Mobile ADAS Technician
I too have much interest in this topic lol
Love the Lightning, but the fact that my VFR750 has a higher top speed…
When I have the "need for Speed" my 2012 ZX14r does the trick
Ted23Lightning
Ted
You all are going to make me miss my snowmobiling days. Nothing like bombing across a lake at a buck fifteen, in the dark and blowing snow, and have a fishhouse suddenly flash by....
There is a FORSCAN setting related to Police use that says "max speed". I dont believe it will have any effect on our trucks but might be worth a try.
I’ll have to test this… in Mexico or Canada 😏
theawesomegamer
Alton
Utah
I just checked the tires on my Lariat ER on stock wheels and the speed rating is T. That’s 118mph/190kph. So the tires are good up until then.
davidnewbern
2022 F-150 Lightning Pro
Physician
I purchased a slightly used F150, lightning Pro, 2022. It was formally of Fleet vehicle that had A 75 mph speed governor pre-programmed into the vehicle.
Yes!
After two trips to the dealership, they learned that they had to reprogram the PATS System (passive antitheft system).
This is includes the ‘My Key function’.
This finally removed the 75 mph speed governor on my F150 pro lightning, that had previously been a fleet vehicle.
This information was not readily available to the service department and required several consults through the “Ford Hotline” by the service dept to finally get the solution.
Hope this helps
astrand1
Alex
Studio truck driver
Yes!
Hope this helps
That could have been done with forscan at home. All that dos it put the truck back to its stock speed limiter.
Right. Removing a MyKey limit does nothing to the governor.
Keep in mind that these trucks record and store everything. So, if you did get it removed or raised, drove it at say 125mph, and then in the future had a warranty claim, they'd know.
I had a boat that got some warranty work done a few years back. It was nearby. Tech called and said "I have to record some stuff that I forgot to pull for the warranty claim, can I stop by?" Plugged in a cable to a PC, and within seconds said "you have X overrevs on this day and that day"... I said "yes, that's what happens when you pop over a wave and the prop comes out of the water". He laughed.
