- First Name
- CHRIS
- Dec 16, 2022
- alexandria virginia
- 2023 F-150 LIGHTNING, 2012 Nissan Leaf, 2015 Toyota Prius, 2000 HD 883 Sportster
- Occupation
- Patent Atty / Electrical Engineer
I get the same ball-park miles/kWh numbers with my 2023 Pro.I have had my 2025 Lightning FLASH for a little over a year now and have a little over 17,000 miles on it. I decided to do a calculation of what it costs me per 100 miles to drive my truck. I live in the Phoenix metropolitan area and during the summer I average about 2.3 miles per KWh and in the winter I average a little over 2.6 miles per KWh. I decided to use 2.5 as an average for my calculations so I use about 40 KWH per 100 miles. I have a FCSP at home and charge exclusively at home except when I drive to LA or up to the mountains. My FCSP shows that I use between 7.1% and 7.5% more energy to charge my truck each time I charge. I decided to use 8% to be conservative which means to add 40 KWh to the truck I will use 43.2 KWh from the power company. I charge only at night starting at 10 PM and the rate I pay through my power company is 5.943 cents per KWh off-peak in the summer and 3.495 cents per KWh during super-off-peak hours (10 PM to 3 AM) in the winter. If my calculations are correct then the cost to drive 100 miles is $2.57 (43.2 * .05943) in the summer and $1.51 (43.2 * 0.3495) in the winter. Why would I ever spend money on gasoline again if my calculations are correct?
The only difference is when calculating my cost per mile.
I add in all the charges on my electric bill to get the actual bottom line cost (stuff like fuel, taxes, transmission charge, etc), so I wind up with more like 13 cents per kWh for example, my number from Sept. 2025.
I also include the "wasted" energy not just the energy added o the battery.
Even so I still ended up with a cost of less than 5 cents per mile in Sept. 2025 where my miles per kWh was 3.2 (mild weather, local non-hwy driving, speed limit obeyed, no aggressive driving).
My 2012 Nissan Leaf does better at 4.9 miles/kWh frequently.
Our 2015 Prius gets on average 50mpg Hwy and with gas at about $2.63 it is comparable dollar per mile wise to the Lightning, leaving out the "hidden" costs of air pollution, etc. of course.
