Front shock replacement ?
Ltron
Murrells Inlet SC
23 Lightning XLT ER , 24 Lyriq AWD Lux1
Ret
What is the best front shock replacement for 23 LR to firm up front without changing ride height ?
Was thinking Biestein but can't get a get a recommendation from them..
Thanks , Bruce
nate002
nate
ā€˜24 Flash | Antimatter Blue | 9.6kW Pro Power
I put adjustable Eibachs on mine (set to the highest position to also level the truck), and it’s made the floaty ride disappear. I have the Eibachs for the back too, but I haven’t put them on yet. Just doing the front made a huge difference. No regrets.
https://www.shocksurplus.com/produc...1zZwXF89Y4rBemJEDcWBrJx8YuIjq1JlynlW-ROZkMd3k
Edit: To add, I put them on myself with the assistance of spring clamps. I only replaced the struts. I put the stock springs back on. After I was done, I took it to the dealership and had them do an alignment.
csukoh78
Nope
SE USA
2023 Ford Lightning Lariat ER
Thanks , Bruce
Fox 2.0 with new ICON tubular control arms. VASTLY improved. Thank me later.
nate002
nate
~$300 vs $2,500… you buying? lol
nate002
nate
I don't go cheap. Buy once cry once, buy cheap cry everytime.
I get the best or I get nothing. It's the basis of the 5 year rule and serves me flawlessly.
Just because you spend less money on something doesn’t mean the thing is ā€œcheap.ā€ The Eibachs are great struts and provide a solution for OP’s question at a reasonable price. They also come with a lifetime warranty.
Paying $2,500 plus another $1k or so I’d imagine having someone install all that for 10% more benefit isn’t worth the cost difference. It’s a cost/benefit analysis, not cheap vs buy once cry once. I mean, congrats on being able to ā€œget the bestā€ of everything. I guess if you have the kind of disposable income to just buy whatever, that’s great. But unless you’re jumping sand dunes, that Fox kit is completely unnecessary for driving on the highway.
21st Century Truck
Martin
Thanks , Bruce
I strongly recommend the Eibach shocks. I have had them on for months now and couldn't be happier.
FYI - I reused the OEM springs and set the Eibachs at the OEM Lightning height (i.e. the lowest shock circlip setting all around).
Also - my Ford OEM shocks were all worn out, front and back, by around 60 thousand miles. Once I took them off, it was really obvious.
roddiaz1
Rod
Pittsburgh
Very intrigued by your philosophy. I have been a cheapskate most of my adult life, and as I look back, I think I would have done better adhering to something closer to what you have laid out.
My conclusion is: I wish I had less. Much less. But that things that I did have, I would want them to be the very best (or at least the best I could afford). Accumulating junk is a losing proposition.
Now, all I have to do is live it out.
Bokenator
Curtis
Georgia
2023 Lightning Lariat - Antimatter Blue. 2020 Hyundai Palisade Limited
I went with Eibach shock part # E60-35-061-01-10. Parts and professional installation (including alignment) cost me about $700 total for the front only. They can be set to different heights, I set mine to about 2" of lift, which levels the truck (about 1/2" of rake remains). Get rid of float, still happy after about a year and 12k miles.
csukoh78
Nope
SE USA
Have you heard of the "Boots-theory"?
Ford F-150 Lightning Front shock replacement ? IMG_8979
nate002
nate
There are companies that make a lot of money based on this philosophy.
They create something that may be slightly ā€œbetterā€ than everything else, then jack up the price 10x and sell it to people like you. Something something a fool and his money.
csukoh78
Nope
SE USA
What a damaged and sad world view you have.
Quality products that demand a premium are often time proven and reliable. No one is buying something because it's expensive. We buy it because it's quality. And quality lasts and is cheaper in the long run.
Sounds more like projection because you've been suckered in the past. Better luck in your future decision making.
roddiaz1
Rod
Pittsburgh
Firn, You sound like an economist. Remind me what do you call when companies have different price points for basically the same good or service. I think the standard example was gyms would offer a Platinum, Gold and Silver membership for the exact same gym, yet the monthly prices were different. What is that called? Something related to consumer surplus, right?
