How to clean between the cab and bed?
Pacific.NW
Christian
Vancouver, Canada
2022 Lightning Lariat ER
Where do I find “truck floss” to get out all the cedar droppings and other crap that has accumulated in that gap between the cab and truck bed?! My regular hose on the “jet” setting doesn’t seem to cut it. Any tips?
Additionally, the “felt” (or whatever fuzzy fabric it is they’ve adhered in that gap) seems to have some moss or algae… curious as to what anyone might recommend to clean and curb that growth.
chriserx
Louisiana
I haven't really thought about it but a pool noodle would prolly fit. Dunno what exactly you're dealing with but fishing line would floss it, guess you could blow it off the pack with a shop vac. Haven't done any of this myself, just speculating.
Pacific.NW
Christian
Vancouver, Canada
Oh yeah, very regional, and doesn’t help that I have several large cedar trees around my driveway! 😂
Here’s a view of what I’m describing…
Ford F-150 Lightning How to clean between the cab and bed? IMG_6035
I don’t think fishing line would work, that’s too slick. Maybe some sisal / hemp rope to LITERALLY floss down there? lol
chriserx
Louisiana
Yeah that was way worse than I expected...I'll never complain about my pine needles again...well maybe not never...
Lytning
Georgia
Wow. Plant some flowers or vegetables in the gap? 😂
hermits-stunt
Gator
MI
‘23 Lightning ER Platinum
Would a compressed air blow gun work. $10 at Home Depot.
Primefit - 2 ft. Blow Gun
Pacific.NW
Christian
Vancouver, Canada
I tried the leaf-blower and the exhaust from my shop-vac with the narrow nozzle, but the additional power from a compressor might be good… may also need a wand to reach down into the crevice! Thanks for the tip.
cobracosta
matt
San Diego
2023 f150 lighteninig
Medical imaging
maybe use a wire snake to clean out the space? add a bottle brush? Yea pool noodle stuffed in there after its clean will slow down the needle collection. ( paint the noodle black with rhino lining)
SFsparkie
2023 F150 Lightning Lariat ER 01/23
While camping I’ve had the same experience. I have successfully used the flat duster on a stick designed for cleaning under the refrigerator. It can also be used sprayed with car wax/cleaner after the dirt is removed. Once I have used mule tape only because I had it in the bed for tie down rope. Mule tape is a flat rope used to put in conduit to measure for wire length and bring the pull rope through the pipe. It is often discarded by electrical contractors.
Robocop
2022 Platinum; 1962 Lincoln Continental
I have had this problem as well and would love to hear about solutions. in my case red pine needles and small pinecones fell back there. except in my case, the rubber sound deadening insulation (I assume) was peeling back off the back of the cab and these needles and crap fell back there in between the insulation and the cab. It looked like a magic carpet with the ends rolled up and the rest of it lying flat.
I complained about it a bunch to two different dealers. One dealer attempted a repair two or three times, I believe, before they decided to keep the truck, pull the bed and do whatever to fix it, hopefully for good. I'm pretty sure someone along the way tried to just glue the insulation down over the debris in prior repair attempts, which obviously failed and they had to do it again. They also got glue everywhere - on the back glass, across the back of the cab and down the side there in the gap, and even a few spots on the plastic bit running along the top of the bed. Suffice it to say, I was pissed.
They used to make giant Q-Tips for just such an issue?
A pressure washer with a low pressure nozzle might work.
Or ask your local car wash detailer, maybe they have a good idea?
Maybe rubber weather stripping to keep the stuff out in the first place, like what's used on around door openings or for truck caps?
ronscantlin
Ron
Orlando, fl
2022 f150 platinum
Need to get that out of there before it dries out and falls onto the hot exhaust.
COrocket
F-150
I would just get a wooden dowel rod from HD/Lowes and start picking at it
tshea95476
Sonoma, CA
Very similar to wooden dowel Iea I found that the fiberglass "glow rods" that electricians use to reach through and grab cables work great for this. And they are made up of short pieces that are screwed together so they are as long as you need them to be.
I <3 My Lightning
My 2 cents. Pressure washer is a no and a possible yes... It's a no if want to blow water back through cab back wall pressure vents... But you can also drop the seat backs, take off the padding and block off...
This is a job for duct tape, another person, and some rope that would fit.
I think you can figure out what to do from there... floss away.
