Grind or popping noise at slow speeds
mq019
2023 F150 Lightning Lariat ER
Did you have this noise too, is that why you took yours in? Or how did you know there was a problem with yours?
Hard to tell if it sounds exactly the same as what you have there in your video.
If its a CV join issue, you'll hear it more and more as it gets worse (it gets louder), and will hear it more when accelerating and if you make a tight turn (binds up the CV knuckle).
After I started noticing it on mine, I took my truck to a quiet parking lot, rolled all the windows down, and took some tight turns, and did some acceleration from a stop - you should hear it clunking and/or kind of a grinding noise - I thought for a while that I had gotten some gravel behind the caliper or something that was rattling around.
took it to the dealer and they found the issue right away - the only problem was parts availability (which makes me wonder if this might be a more common issue than we know since I don't understand why they wouldn't have some in stock somewhere in the country). Ford EV folks were involved and paying for my loaner the whole time, it just took a while.
Reactions: chl
Bigisland Guy
Ed
So Cal
Retired Old Dude
I had the issue on my old 23 and the TSB resolved it, but mine never popped like yours.
POST ONE has the PDF of the TSB
dpwmc93
Dennis
West Bloomfield, MI
Ford F-150 Lightning Flash
Senior IT Support Specialist II
I did some research online and found this...
Based on the description of low-speed, intermittent grinding/popping while turning or backing up, this issue is commonly related to front differential actuator vacuum issues (IWEs), front CV axles, or steering rack binding. Given the leveling kit and larger tires, the CV angles are increased, making it likely a binding joint or vacuum-related issue.
Potential Causes and Fixes:
  • IWE (Integrated Wheel End) System: On Ford trucks, a failed IWE check valve or cracked vacuum line can cause partial engagement of the 4WD hubs at slow speeds, resulting in a grinding sound. This is common with leveling kits and is often mistaken for a transmission or bearing issue.
  • CV Axle/Joint Damage: The grinding/popping while turning at slow speeds strongly suggests a damaged or binding CV joint.
  • Steering Rack/Turn Stops: If the sound only happens at full lock, it may be the tires rubbing on the sway bar/control arm, or the steering rack itself making noise, though your tire shops' feedback makes this less likely to be just a simple rubbing issue.
Recommended Next Steps:
  1. Try a Different Dealer: Take your videos to a different dealership that has experience with lifted/leveled trucks.
  2. Request Specific Checks: Ask them to check the IWE vacuum pressure and perform a "vacuum test" on the hubs.
  3. Inspect CV Joints: Have them inspect the front CV axles for torn boots or play.
  4. Reference TSBs: Mentioning Ford Technical Service Bulletins regarding "IWE grinding" or "suspension clicking" can help focus their diagnosis.
My 2001 Ford Ranger made the same noises.
They happened when I turned - the rubber boot(s) around the CV joint(s) had worn out and torn.
The Ford dealer repair was not cheap, around $1,000, probably replaced both I don't recall.
The truck was not high mileage but was 13 years old at the time.
Being suspension related, could OP jump around in the frunk/bed to test diagnostically to help narrow the cause?
Not really, that that only works for more obvious problems.
mq019
Its definitely not an IWE issue - thats an ICE issue. These trucks dont have that system -they're full time 4WD/AWD
Kyle
2025 F-150 Lightning Lariat
After watching the videos, I second the suggestion that this is CV axle (halfshaft) related.
Reactions: chl
chuck27p
chuck27p
Chuck
Orange County, CA
2023 F150 Lightning Platinum Black
Update: Took it to Ford. Here's what going on apparently (fingers crossed, I pick it up today and will drive it for a week and hope the noise is gone as they say).
"Alignment adjusters loose causing flex noise while moving and turning. Aftermarket caster/camber adjusters and shocks. Torgued lower control arm bolts and lower shock bolts. Some noise from front skid plate from impact, corrected bend too."
If this is correct, then two off road shops didn't torque bolts to spec. Easy fix. Ford also has an alignment rack and they did the alignment afterwards and sent me the report, which is great, most shops around here don't have that and do it by hand.
With a little luck, everything should be back to normal. I'll report back in a few weeks.
wapple24
New Jersey
I have had a squealing noise when turning the wheel, twice now. Dealer is replacing my driver’s side front control arm for the second time. Thank goodness for extended warranty.
  • Wow
Reactions: chl
