- First Name
- CHRIS
- Dec 16, 2022
- alexandria virginia
- 2023 F-150 LIGHTNING, 2012 Nissan Leaf, 2015 Toyota Prius, 2000 HD 883 Sportster
- Occupation
- Patent Atty / Electrical Engineer
My understanding is battery desulfation will work to some degree if the sulfation hasn't gotten too bad. But it is not going to make the battery like it was brand new again.Anybody try a charger with a Desulfation mode to resurrect one of these factory batteries back to proper SOC range?
It may or may not be enough to restore it to the level needed.
Someone could try it and see what the result is.
Be sure to disconnect the battery from the truck before you begin, the desulfation process could damage sensitive electronics as I understand it.
I once tried the battery repair mode on an old gel type battery that came with my gas generator that had been sitting for a long time unused in a shed with no electricity, but no go. I think it had probably dried out.
Using a battery maintainer is the way to go once you get a new battery, to keep it healthy longer.
An ounce of prevention as they say!
