New 12v battery and reset BMS but still getting “update failed because vehicle battery too low message
SeanOC
LINY
‘18 Raptor ‘21 Tesla Model Y
Pilot
Hey guys. I’ve been getting update fail message because vehicle battery too low the past week. Truck is 3.5 years old and 50k miles, I went ahead and put a new 12v in and upgraded to the H4. I reset the BMS after install.
Unfortunately I’m still getting message a few days later. Vehicle is charged to 90% and left plugged in overnight (updates scheduled for 2am).
Any thoughts?
Ford F-150 Lightning New 12v battery and reset BMS but still getting “update failed because vehicle battery too low message IMG_3481
Try switching the headlight to OFF.
Switch off the sound system.
Switch off truck.
Set parking brakes.
Start Install now.
Get out & Lock doors.
Force stop your mobile app easy to do in Android, not sure how you do it in iOs.
Walk away with FOB and leave them still in the house/office for the projected duration of the install.
Hopefully you have success
rpritchett2
Bob
Houston, Tx
2022 Ford Lightning
I had exact same issue. Tried the resets, but no joy. Took my truck to dealer and tech reset BMS with his Forscan tool. They also took care of some recall issues.
Sleazy-E
Greenville, SC
2023 Antimatter Blue Lariat ER
Any thoughts?
Check the BMS part number. This caught me when I bought used and was having the same exact issue.
https://www.f150lightningforum.com/...nc-cold-weather-performance.34418/post-651587
Tony Burgh
Tony
Western Pennsylvania
22 Lariat ER
Switch off truck.
Set parking brakes.
Start Install now.
Then you do the Hokey Pokey and you turn yourself about.
Boomerboy
2024 F150 Lightning Flash
Any thoughts?
When I replaced my 12v and reset the BMS truck did not totally reset the BMS until I drove the truck about 30 miles. After driving the truck 30 miles then letting the truck set overnight everything was fine.
tearitupsports
Russell
Cypress, TX
A couple of notes.
Just having the truck plugged in does not maintain or charge the 12V battery. It is only charging when the truck is "ON" or when it is actively charging the HV battery.
Low 12V battery is quite normal for people who make frequent but short trips and thus short charging sessions.
The ideas above are what you need to do. Keep the truck "ON" for several hours by turning off the 30 minute timer, and shutting off the lights as well as the AC system. This will work for most people.
As noted above, make sure you have the correct battery monitor part as well. 22 and 23 trucks had a recall for the battery monitor, and I don't think all vehicles had this completed. The link posted above will take you to another link that shows how to read the bad and good part numbers.
SeanOC
SeanOC
LINY
Pilot
Yes unfortunately I have the an early ‘22 model and I have one of the recalled BMS sensors.
Will call the dealer on Monday.
I’ve tried all the other recommendations listed above but not luck, thanks everyone for the advice.
Yes, I concur that if the normal ways to solve the issue didn't work, then likely a bad component in the 12v system, as others mentioned, and a trip to the Ford tech or dealership is the last resort...er, uh, I mean the easiest solution.
Keep us posted on the solution and the $damage$.
jwrezz
1996 Ford ExplorerXLT, 2006 Subaru OBS LLBean, 2024 Ford F150 Lightning Lariat
Teacher/Firefighter
Reactions: chl
SeanOC
SeanOC
LINY
Pilot
Thank you! I have one of the bad part numbers. My truck is an early ‘22 model
should be covered under my extended warranty or the recall, but yes I will definitely update here
Reactions: chl
Good for you getting an extended warranty - I did the same!
Tfarrell73
Tim
New Lenox, Illinois
23 F150 Lightning Lariat ER
That was CSP not a recall. I believe CSPs do expire but not sure about specifics for the BMS CSP 23B70
Yes, that one expired Jan 2025 I believe, but under the extended warranty since it seems to be failing, should be covered.
Ford F-150 Lightning New 12v battery and reset BMS but still getting “update failed because vehicle battery too low message CSP 23B70
