tearitupsports
- First Name
- Russell
- Jun 1, 2024
- Cypress, TX
- 2023 F-150 Lightning Lariat ER
- Occupation
- Industrial Automation & Controls
While something like Sigenergy is definitely more expensive than DIY cobbled together system, if you are starting from scratch it is not that bad. Even when comparing to something like EG4 it actually isnt that much more, especially considering you are tapping into 130 kWh of battery.
In an off-grid scenario, you don't need to buy the transfer switch so that saves about $1200
What I haven't seen mentioned is if there is an existing solar array or not. If you don't already have solar, keep in mind that the Sigenergy inverter also has 4 MPPT, so it is a piece of equipment you already need.
If you do get the V2X it is also a charger, and you don't need to buy a different one, or the cost of all that extra wire. Certainly not a 1:1 exchange, but a little offset.
My point is that you really need to add up the cost of all the other stuff including cabling (possibly labor), and other factors when comparing your best options.
At full online retail price the Sigenergy inverter, a 9 kWh battery and the V2X module would be $9k.
All you need to add is a 60A breaker to your main panel along with the 6 AWG wire run and 3/4" conduit. You then would add your solar panels and the length of 10 AWG DC solar cable / metal conduit as needed.
If you add the load hub for about $1200 (or less as a bundle option), you can add a generator input for any generator up to 80A. I would certainly recommend that in an off-grid scenario.
Use those numbers as a comparison to the other options you are looking at. I am sure you can put something together for less than that (probably half the price). It is up to you to determine the value of the quality of life. Do you want to be always fiddling with your system and changing cabling, or do you want something elegant that you hardly think about?
