Tony Burgh
- First Name
- Tony
- Sep 28, 2021
- Western Pennsylvania
- 22 Lariat ER
- Occupation
- Retired
Waiting for Godot, eh, Enphase.
That's what I thought it was. Sorry for the confusion.-
.... at first, this looked like an easy 'V2H' connection method, but it seems like this is just for EV Charger wiring outside of the traditional connection to a Main Panel breaker.
A quick look at that website and I didn't see anywhere to connect power cord from a Lightning Pro Power to this meter socket.Not sorry. It is. They have both options. This one and the one I shared from Solar Surge YT was the home back up. https://connectder.com/products/islandder/
No, it's a battery storage connection. I guess it could be used with a generator or the lightning's outlet. It's just an inlet with a breaker it seems. Says its meant to work with it's MID so no transfer switch or lockout/interconnect. An MID should be able to work with any type of input, but they are saying for solar or battery systems.A quick look at that website and I didn't see anywhere to connect power cord from a Lightning Pro Power to this meter socket.
I believe it's all hardwired. You can wire up a receptacle, but they are expecting some type of off-grid, or hybrid inverter and battery storage system that would be the direct connection and then the inverter may have solar and generator inputs, like from PPOright, as I could not locate any NEMA 14-50 or 240v Twist lock connection on the unit, to allow for the incoming power from the truck... or are they are expecting your vehicle to provide this directly thru the J1772 cable?
My thoughts exactly. That wouldn't be "legal" or to code, but that's exactly what needs to happen for it to function.Did you ask if their "Ford Connector Cord" just doesn't connect the ground lug at the ProPower plug to their 20ft cable?
I did not ask. Their Product Support is at 800-886-3837 Mon-Fri 8am-4:30pm. I found them helpful.Did you ask if their "Ford Connector Cord" just doesn't connect the ground lug at the ProPower plug to their 20ft cable?
