- First Name
- CHRIS
- Dec 16, 2022
- alexandria virginia
- 2023 LIGHTNING PRO, 2012 Nissan Leaf, 2015 Toyota Prius, 2000 HD 883 Sportster
- Occupation
- Patent Atty / Electrical Engineer
Yes good point! Some people might have their meter in a sheltered area - I don't.I think if my Home Integration System just goes belly up someday and I can't get it fixed by Ford or Sunrun, I'll just switch to a transfer switch and be happy with 7.2 kW from the truck bed. The Enphase IQ Bidirectional Charger seems too expensive, and will it work with the Lightning if it doesn't fully support ISO15118-20?
On the Generlink transfer switch, I have no desire to go out in pouring rain with thunder and lightning and plug the Generlink cable in near my very exposed meter. Another brilliant idea from @Ford Motor Company! So, I will go with a transfer switch setup that I can operate from inside my house that will feed my main subpanel (all lighting and electrical outlets in the house) as my Home Integration System does now. And, as I have promised before, if Home Integration System support fades away in the coming years before the useful life of my vehicle expires, and Ford never fixes automatic Backup Power Transfer, I will never, ever buy another Ford motor vehicle and discourage all friends and neighbors from buying one, too, as Ford so far has completely blown off an expensive complex feature that it advertised initially as a premier reason for buying a Lightning.
I think I read that you could leave the cord plugged into the meter when not in use. Put a hose hanger there and wrap it up, if secure.
I usually plug up my generator cord and get everything ready when I see a report that weather is approaching.
To use the PPOB, the truck has to be ON unless you do the FORscan tweak to have PPOB with the truck OFF, so braving the elements has to be done at some point unless I leave the truck ON for hours while I wait for an outage.
I have done both - had it ON all night when we had a snow and ice storm - no outage though.
Since I installed my GENERAC 6853 manual Transfer Switch in June of 2025, no outages yet.
One of the recent OTA updates caused the reserve setting to not work correctly - I saw a post about the issue and I tested mine and same problem - set a reserve, run the PPOB backup, PPOB turns off way before the reserve is met.
The workaround was to use the nearest charge station option instead of the miles for the reserve - then it defaults to 10 miles - go figure!?
And when I did the FORscan tweak and tested the PPOB with the truck OFF, after about an hour of so, I looked outside and my Frunk was open! It did it by itself! I think running PPOB with the truck OFF might have drained the 12v battery and caused the Frunk to open - no other explanation I can think of.
Sorry about the HIS. But thanks to everyone here for telling us about all the troubles.
You might see about a BlueTooth booster transmitter/receiver since the biggest issue seems to be the communication. Have to figure out where the truck BT antenna wire is and then hook it up there.
