So your argument is that if I can turn on say 8 features from a Platinum in my Lariat, but I can't get the different metal trim and seats, that I don't have a Platinum and therefore Ford hasn't lost any money? Umm, ok.Is the topic not relevant because it was from 6 months ago?
So the ONLY difference between them is the feature turned on via Forscan? Again, yes, I know you can turn on features from higher trims, that still doesn't MAKE it a higher trim, I was clear about that. Happy to hear which two trims vary only by changes that can be made in forscan
I'm sorry, are you saying you can enable Bluecruise without paying for a subscription? Simply via Forscan changes?
Again, which individual feature, or set of features, that can be enabled by forscan would be the same as something you could pay for. I know you could get them in higher trims, but you also get a LOT of other things in higher trims too, not just features enabled via forscan.
