Ted23Lightning
Ted
23 F-150 Lightning Lariat ER, 2014 Honda VFR 750 Interceptor
Mobile ADAS Technician
I made a quick YouTube video showing my Comma Four setup with some tips. It’s my first attempt so please forgive the production and editing. I learned a great deal from watching @branden and his Comma AI and other videos and just discovered a few other tips along the way. Hope it helps someone else
Good video. Did u experience any issues with/ during the setup?
HunterHan
Curt
New York
2024 Ford Lightning Lariat ER
I experience that some times my speed settings on the dash runs wildly up or down. How do I turn off this feature? Do I have some auto adjust speed on?
If
The main issue was getting all the settings dialed in. I put all the settings in Chat GPT and asked what exactly the setting did and what worked best for my Lightning. That really helped to get it right. I did the 12 volt battery reset after the first getting a ton of faults which is normal. Afterwards, no more warnings.
GrokTime
Sean
Ithaca, NY
2022 F150 Lightning, Rivian R1S 1st Gen
Hey ya'll, wanted to drop in and bump the links for the coupler since I have been getting a lot of individual reach outs for them.
https://bluepilot.dev/lightning-coupler-order-page/
Make sure to check out the dock integration as well
https://bluepilot.dev/dock-order-page/
I am about to pull the trigger on a Comma. Still trying to figure things out. When ordering a sliding dock there is an option for a FitCamX relocation bracket. It seems this does not cost extra? Does it change the sliding dock itself or is it an extra bracket that is thrown in? I don't have a FitCamX but was considering it and not sure what choosing that option actually does.
UncleTony
Tony
2023 Lightning Lariat
Cybersecurity Engineer
@Ajzride
Ajzride
Alan
Houston
Eng
It is a free option. It is a bracket that screws to the rearview mirror where the FCX would screw to, and then has an arm to move the FCX over 5" towards the passenger side. The FCX is still invisible to the driver (hidden behind the rear-view mirror), but the comma can now be centered. Leaving the FCX at the base of the mirror means mounting the comma low, and having issues with driver monitor, or mounting it to the side and having issues with ping pong.
Ajzride
Alan
Houston
Eng
Did you turn on ICBM? It's a beta level feature to let the comma adjust the speed stepping by simulating the steering wheel button presses.
Ajzride
Alan
Houston
Eng
So, I got my Comma 4 a few months ago. Installed BluePilot, and I believe WD40. I was awesome. Kept it on almost all the time, even when driving local streets and I was doing the driving. Seemed like a good backup.
Then I got some error, it couldn't boot out of nowhere. So I reset it, and reinstalled bp-6 and activated WD40.
Now it is insanely annoying. Worse than Bluecruise. Annoying beeps all the time. Turning off due to inattention all the time. Telling me to hold the wheel all the time (even when I am actively driving). It is trash.
What's going on? Where is the "driving attention" model located? Was it some SunnyPilot or bp-6.0 thing that changed?
Whatever happened, it has gone from a great system to something so annoying I barely want to use it. I'd like to get it back to how it was a couple months ago, when it was awesome.
Help appreciated.
Comma updated the driver monitor software to specifically watch for phones. If you have a phone in your hand, or on a dash mount where it can see the phone, it will trigger the warning and countdown. Several people have had to remount their phones because it was in the comma field of view and it thought they were playing with it.
Balu
Is there a way to revert versions or something so it goes back to being useful?
GrokTime
Sean
Ithaca, NY
Thank you. And just so I am clear, the sliding dock itself is identical whether or not you get the FCX bracket?
GrokTime
Sean
Ithaca, NY
Thanks. I just submitted an order form.
I am about to order the Comma.ai itself. Is there a referral program I can use to help anyone out?
Anders
Anders
F150 Lightning Lariat 2022
Tower crane operator
Yes, that was the main issue. I think the sub-settings might be arguing a bit. SSC vision and map seems to work better with only one selected.
Ajzride
Alan
Houston
Eng
only choose one. Combined will cause them to fight each other.
branden
Branden
'22 Lightning Lariat ER
Is anyone working to improve this? Shouldn't driver monitoring get more lenient as the ADAS improves instead of more strict?
