The DC/DC converter should be maintaining the LVB {12v} normally in full run mode.But, still, the 12v battery could be the problem. Research is continuing! Thanks for your thoughts.
Yes, it should, but...when the current draw is high-ish, it still needs the battery...which is basically why short-trip driving and parasitic drains kill batteries over time even in ICE vehicles - they never really get topped off.The DC/DC converter should be maintaining the LVB {12v} normally in full run mode.
I will have to test that this afternoon. I have PPOB on with about a 50 watt load for about 16 hours. I do have the truck on L2 charge at this time. Note that I have observed one change sometime or another. A 50 watt load on PPOB is resulting in PPOB with the truck off NOT timing out. I thought in the past it took a higher continuous load to keep PPOB running.While running another test of the PPOB with the truck OFF, I accidentally touched the climate button on the FORD app screen and the whole thing shut down...PPOB shut off that is.
The shut down when I accidentally touched climate with the PPOB ON and the truck OFF turned the heated seat ON full blast (all bars).I will have to test that this afternoon. I have PPOB on with about a 50 watt load for about 16 hours. I do have the truck on L2 charge at this time. Note that I have observed one change sometime or another. A 50 watt load on PPOB is resulting in PPOB with the truck off NOT timing out. I thought in the past it took a higher continuous load to keep PPOB running.
It's powered by the 12v LVB system.I am guessing the heated seat uses the HVB.
Thanks for the info - I had seen conflicting info about which was powering it.It's powered by the 12v LVB system.
