Hansshow NACS to CCS1 Extension Cable
Lightning Rod
The North Coast
2023 Ford Lightning Lariat ER
PROGRAMMER
Does hansshow make a nacs to nacs extension cable? I went to their site and appears that they may not. :unsure:
It’s probably not universally true, but one would expect vehicles with a NACS port to have it in a location compatible with Tesla charging stations!
Lightning Rod
The North Coast
PROGRAMMER
We have a Toyota BZ and the nacs port is on the passenger front fender but you have to pull .5 inch from the stall and we still have to stretch the cord and put tension on the port door. It's ridiculous. 😐
MidAtlanticLightningClub
F-150 Lightning Lariat ER
New Chevy Bolt has the charge
new Chevy Bolt has the NACS port where ours is on front left
SFsparkie
2023 F150 Lightning Lariat ER 01/23
Used the 8’ Hansshow NACS to CCS1 Extension Cable for the second time at the Santa Cruz Tesla station in 93° temperatures today. There were only two spots available and neither spot could reach the Lightning with the Tesla cord. The extension worked flawlessly from 36% to 80% (added 63.3Kw) in 40min. Charge port temperature reached 134°F. Cord was warm. Charge rate peaked at 119Kw. Guess I will remove the plastic on the cord since I’m thinking about keeping it.
Ford F-150 Lightning Hansshow NACS to CCS1 Extension Cable IMG_1926
