Tire day!!
Slight upgrade!
295/70r18 Nokian Outpost nAT.
Its still up in the air so no, no efficiency numbers! That said, i did a controlled 60 mile, 70mph, drive just last weekend and will do the same exact drive soon.
Ford F-150 Lightning Tire day!! 20260630_152306
Ford F-150 Lightning Tire day!! 20260630_152315
Big tire....what are the % numbers on the tread?
Nolander
Scott
Why do they look so much larger than the old shoes?
UWmad
bart
2023 larait
I'm assuming shocks or a lift were needed for the larger tire?
Because they very much are!
No actually. I was expecting some rubbing since I have yet to install the leveling kit but so far nothing touches.
Ford F-150 Lightning Tire day!! 20260630_072526
Ford F-150 Lightning Tire day!! 20260701_073905
Ford F-150 Lightning Tire day!! 20260630_072451
Ford F-150 Lightning Tire day!! 20260701_073816
Dspade
Dushan
Fresno, CA
2025 F150 Lightning Flash
Contractor
My new truck rides so well with what it came with I’m not sure I’ll ever change.
is your choice purely cosmetic or are you going for comfort?
Ford F-150 Lightning Tire day!! IMG_4907
Nolander
Scott
These are what came on mine. Still plenty of tread at 30K miles which is the best wear I have ever gotten from a AWD vehicle. I think these trucks are very kind to tires...counterintuitively.
Flipper
Steve
2023 XLT, ER, Lightning, 312A, Azure Gray
Sales Engineer
I am pretty happy with these tires also. I may look at Michelins when the time comes. These Goodyears are holding up pretty well for me too. I'm at 20K miles right now
Honestly, 87% cosmetic, the rest living in the snow states where we occasionally get deep snow, plus the occasional trip off pavement. Comfort was not a driving factor
TenaciousG77
2024 F-150 Lightning Lariat
My only qualm with the stock Goodyears is they don't inspire much confidence in the snow. We had a terrible year in terms of lack of snow, but the few times it did snow a few inches, once the snow gets packed down, I had to creep around town in order to maintain traction. The front end breaks away easily on even the slowest turns, and ABS works overtime on stops that require a bit of extra braking. Maybe in ICE applications, this tread design is fine. But my guess is with the weight of this truck, it gets overwhelmed easily in snow/ice. If snow is sticking to the ground, I don't even think about using 1-Pedal. But in the summer, the tire works well.
DavidS
DAVID
Green Bay, WI
F150 Lightning Lariat
It’s just not cold enough in Colorado. My HT Goodyears did just fine all winter in northern Wisconsin but snow (and even ice) has a lot of traction below 20F.
Dspade
Dushan
Fresno, CA
Contractor
To be honest, ice & snow was never a consideration when making this statement. This is a great point. I live in Central California. Same as SoCal only hotter! LOL. We do have a ski resort an hour away, but when that is in the picture, I'll be going with someone else or taking my early Bronco. cheers!
