Tire life
LightningDan
Daniel
2023 F-150 Lighting Pro ER
Solar Designer Engineer
So what would be the best pressure to run in OEM tires for highway driving. Doing a 233-mile trip to campsite tomorrow.
Ford F-150 Lightning Tire life IMG_4064
Mcgyverrod
Rod
Santa Paula, CA
2023 F150 Lightning Lariat ER (Rec'd 7/13/23); 2026 Lexus NX PHEV
Retired x2
Generally, when I go camping, I have 4-5 adults in the truck along with 300-500 lbs of additional stuff. I top off my tires at 40 PSI to roll better with the additional half-ton weight.
The Weatherman
Dean
South Central KY
That is dependent on the type of tire you have mounted. You should refer to the sidewall to be sure.
The Weatherman
Dean
South Central KY
I have a new set of tires bought and ready to install later this year. The originals are Grabbers and they are down to about 5/32.
With just less than 20k on them now.
Deleted member 12322
Guest
The secret to a long life tire on the lightning is to resist the urge to goose it a bunch. I imagine many of yall are like me and sometimes hitting the juice pedal and spinning the tires a bit for good fun puts a smile on the face. Downside is, you have to eventually replace them!
WXman
Central Kentucky
2025 F-150 Lightning Flash
Meteorology/Transportation
I run 45 PSI cold. I'm shocked that Ford specs such a low tire pressure on a truck with a 8,500 lb. GVWR. I will most likely go with a stronger built tire when it's time to replace for peace of mind.
NW Ontario Ford Lightning
Robert
NW Ontario Canada
Contractor
My last truck was similar curb weight, and went through tires on about the same schedule I see lightning owners reporting here. Just a cost of being heavy I guess. The difference with the lightning is the nice even split of front to back weight, especially in winter driving. This truck is heads and shoulders above anthing I have ever driven in winter.
In our area, it is very common to have two sets of tires for cars and SUV's (winters and 3-season tires on their own rims). This will be my first truck with two sets of tires, since I normally just picked a winter tire that could handle the summer heat without evaporating before my eyes.
For the Lighning I bought a set of Blizzak DM2 on second set of rims for the winter, and will continue with a 3-season tire on the stock rims for the non-snowy part of the year. See how it goes.
1RMDave
23 Lightning XLT ER, 05 4Runner, 94 Miata
I have been seeing 70k miles or more out of A/T tires on my F-250 and my cousins nearly identical F-250. So I would expect that much or more life out of the tires on the lighter F-150 Lightning.
If tires are wearing out prior to at least 50k on your truck, then you've got terrible alignment or a really poor type of tires on your truck.
Lightning and F250 Diesel weight almost exactly the same.
WXman
Central Kentucky
I haven't scaled my Lightning yet, but by the door placard it should be around 6,400 lbs. My 2019 F-250 was 7,700 by the placard, and 7,800 on the CAT scales. Quite a bit heavier.
jeff_h
Jeff
WV
2023 F-150 Lightning XLT ER
Paint-Drying Observer
Today I finally replaced my OEM Goodyear Territory HT, got 72k out of them (got free rotations at Discount Tire every 10k) and could have gotten a little more but with winter here it's the right time to replace. I went with the Michelin Defender LTX ($318 each at DT) as I had Michelin Defenders on my prior EV and had 82k miles on the set when I sold the car, and could have gotten another 20k or so.
The door jamb pressure on my 2023 XLT ER is 42psi, but I normally run 46psi to try and avoid so much outside wear. And as shown in the pics, the center of the tires still had a lot of tread remaining.
Ford F-150 Lightning Tire life OEM_Tires_20251206
Ford F-150 Lightning Tire life New_Tire_20251206
HWT
Massachusetts
I am now at 18,000 miles. I have the Hankook Dynapro AT2 that came with the Lariat. I now have just over 3/8" remaining. I try to keep the pressure at 35-36 psi. I drive very conservatively with moderate accelerations
We will see if they can make it through the winter.
Bushwood CC
Pete
Ford Lightning Flash
teacher
Just had my 30,000 mile checkup and the original tires still have 9/32nds. I asked them to check again as this seemed unlikely but they were correct. So much for EV tires not lasting. Our ICE CRV had to have new tires about 25,000 miles.
Lightning Rod
The North Coast
2023 Ford Lightning Lariat ER
PROGRAMMER
I installed the michelin Defenders last fall and I must say that I am impressed with it's performance in snow and ice so far. I have zero regrets buying them.
Thanks to everyone here who recommended them. (y)
TooManyToyz
Wisconsin
2022 Lightning Lariat ER
I realize that this is close to being a "zombie thread", but I'm at just about 40,000 and will be replacing soon. This time I'm going to keep them at 40-45 PSI because, like most, I have plenty of tread in the center, and almost bald on the sides.
Robert
NW Ontario Canada
Contractor
I have been using 42-44 psi and the wear seems pretty even across the tires todate - 50,000km (30k miles) time will tell I guess.
