Just installed the recently launched Pirelli Scorpion XTM All-Terrain Tire with gas and EV variants. 34" Tires on 20" wheels.
Madtroniks
Madtroniks
Diamond Sponsor
Ford
Here is a small efficiency update primarily done at 65 mph - 70 mph.
I normally get around 1.8 miles per kWh at highway speeds.
With the new tires I got between 1.8 - 1.9 miles per kWh.
Just based off the small trip I can tell the efficiency is comparable to stock.
Now keep in mind, my tires were 2-3 lbs low, my battery temp and motor temps were low as well.
I’ll do more testing today after putting nitrogen air from Costco and letting the battery / motor come up to temp.
Ford F-150 Lightning Just installed the recently launched Pirelli Scorpion XTM All-Terrain Tire with gas and EV variants. 34" Tires on 20" wheels. IMG_5308
Ford F-150 Lightning Just installed the recently launched Pirelli Scorpion XTM All-Terrain Tire with gas and EV variants. 34" Tires on 20" wheels. IMG_5307
Madtroniks
Madtroniks
Diamond Sponsor
Ford
Another small efficiency update where battery and motor temps were at normal levels, speed was around 40 miles per hour driving to and from one side of town to another side of town using city streets.
I got between 2.3 mi/kWh and 2.5 miles per kWh when driving around 35- 40 - 45 miles per hour and mainly around 40 mph.
Keep in mind, my tire pressure was still 3-4 lbs low when hot. I expect slightly better numbers once tires are inflated to 50 lbs.
I’ll give another update once I can get my tires to 50 lbs hot. I don’t feel like using the compressor in the car and rather use the self-serve nitrogen tire pump from Costco at no charge.
Ford F-150 Lightning Just installed the recently launched Pirelli Scorpion XTM All-Terrain Tire with gas and EV variants. 34" Tires on 20" wheels. IMG_5335
Ford F-150 Lightning Just installed the recently launched Pirelli Scorpion XTM All-Terrain Tire with gas and EV variants. 34" Tires on 20" wheels. IMG_5337
hikinbengal
Bay Area, California
Lightning Lariat ER, Outback, Jeep TJ, Audi A3
Engineering Progam Manager
This is interesting data. I'm interested to see how they perform in winter conditions compared to the Nokian Outpost. The tread wear has been amazing on these for me, but I'm lucky if I get 1.7-1.8 on the HWY with mine.
Madtroniks
Madtroniks
Diamond Sponsor
Ford
Hi All,
I want to let you know ahead of time I have made posts in the Sponsor Marketplace for Tires / Wheels about Discount Tire who has recently approved my application to be an affiliate.
I have left all the links in this thread untouched. I have no upside if you buy tires using the links in this thread.
Thanks for reminding me to consider upside to help me with covering multiple forum sponsorship fees of $430 per month.
I hope the transparency helps.
Sponsor MarketPlace Thread - Discount Tire Promotions, Road Hazard warranty and lifetime road force balancing / rotations plus local install options available.
Was this a compensated review, or did you receive the product for free or in exchange for something?
Why are you a diamond sponsor then? There’s gotta be some upside.
Thanks for the review!
And some of us recognize you can be a sponsor AND an a contributing member.
Madtroniks
Madtroniks
Diamond Sponsor
Ford
I got pretty much the same efficiency as stock or slightly/barely better with XTM AT versus stock Pirelli Scorpion AT+
I am running them at 48 psi - 50 psi and sometimes as high as 52 PSI after a long drive.
Here is my most recent run where I charged to 100% and took a long trip around town.
I am charging it back to 100% to see how much electricity is actual replenished.
Primarily 153.6 miles Highway Driving
Ford F-150 Lightning Just installed the recently launched Pirelli Scorpion XTM All-Terrain Tire with gas and EV variants. 34" Tires on 20" wheels. IMG_5758
Ford F-150 Lightning Just installed the recently launched Pirelli Scorpion XTM All-Terrain Tire with gas and EV variants. 34" Tires on 20" wheels. IMG_5756
Ford F-150 Lightning Just installed the recently launched Pirelli Scorpion XTM All-Terrain Tire with gas and EV variants. 34" Tires on 20" wheels. IMG_5759
Mix of 85% highway and 15% city on Pirelli XTM AT.
Ford F-150 Lightning Just installed the recently launched Pirelli Scorpion XTM All-Terrain Tire with gas and EV variants. 34" Tires on 20" wheels. IMG_5801
Ford F-150 Lightning Just installed the recently launched Pirelli Scorpion XTM All-Terrain Tire with gas and EV variants. 34" Tires on 20" wheels. IMG_5794
Ford F-150 Lightning Just installed the recently launched Pirelli Scorpion XTM All-Terrain Tire with gas and EV variants. 34" Tires on 20" wheels. IMG_5798
Stock Efficiency over 28,637 miles is 2.02 kWh
Ford F-150 Lightning Just installed the recently launched Pirelli Scorpion XTM All-Terrain Tire with gas and EV variants. 34" Tires on 20" wheels. IMG_5795
Ford F-150 Lightning Just installed the recently launched Pirelli Scorpion XTM All-Terrain Tire with gas and EV variants. 34" Tires on 20" wheels. IMG_5796
Madtroniks
Madtroniks
Diamond Sponsor
Ford
I swapped out the SL XTM AT with Toyo AT III EV SL to make sure I can safely inflate my vehicle to the minimum specs.
I would recommend waiting for the LT version of XTM AT which can handle more weight / pressure.
I chose the Toyo Open Country AT III EV tires because of the 116H rating / AT EV tires / Price.
I had to work with an associate at Discount Tire after ordering the tires to get them from a different store and have them shipped via Fedex next day at no charge. These SL tires are in low stock compared to the LT version
The 1-5 days shipping time was accurate for me. I did call my local store to make sure they can order it or get it from another warehouse / store.
Here is the initial pictures from the install.
Just driving 4 miles I got 1.92 mi per kWh. I would expect this to go up once I’ve driven 20+ miles instead of short trips.
I’ll drive more tonight and report back with proper efficiency numbers and once i get all tires to 50 lbs hot.
Ford F-150 Lightning Just installed the recently launched Pirelli Scorpion XTM All-Terrain Tire with gas and EV variants. 34" Tires on 20" wheels. 1747412236011-tn (1)
Ford F-150 Lightning Just installed the recently launched Pirelli Scorpion XTM All-Terrain Tire with gas and EV variants. 34" Tires on 20" wheels. 1747412357261-a9 (1)
Ford F-150 Lightning Just installed the recently launched Pirelli Scorpion XTM All-Terrain Tire with gas and EV variants. 34" Tires on 20" wheels. IMG_6315
Ford F-150 Lightning Just installed the recently launched Pirelli Scorpion XTM All-Terrain Tire with gas and EV variants. 34" Tires on 20" wheels. IMG_6311
Ford F-150 Lightning Just installed the recently launched Pirelli Scorpion XTM All-Terrain Tire with gas and EV variants. 34" Tires on 20" wheels. IMG_6317
Ford F-150 Lightning Just installed the recently launched Pirelli Scorpion XTM All-Terrain Tire with gas and EV variants. 34" Tires on 20" wheels. IMG_6308
jetfixr1
Manny
Atlanta
Its been some time since your last update. Any new info, can you say which one you prefer (Toyo vs Pirelli's)?
Madtroniks
Madtroniks
Diamond Sponsor
Ford
Stock Pirelli Scorpion AT+ did a great job with handling on road and cornering grip. They worked fine for light off-roading but some folks mentioned the snow handling was not best.
Pirelli XTM: I had these for a short amount of time but from what I can tell they tend to perform a little better in cornering compared to Toyo.
Toyo Open Country AT III EV: Good all around performance for on-road / off-road and snow. I prefer the cornering / on-road grip from the original stock Pirelli Scorpion AT+. These are the tires I have on currently I am happy with them for the most part. I might look into a dedicated set of Michelin ultra high performance tires / 22" wheels for when I want extra grip on-road.
WXman
Central Kentucky
www.facebook.com
2025 F-150 Lightning Flash
Meteorology/Transportation
So are ALL of the Pirelli XTM tires in that size automatically the "Elect" version? Or do you have to specifically hunt down a set of the "Elect" versions? It's pretty confusing.
Madtroniks
Madtroniks
Diamond Sponsor
Ford
WXman
Central Kentucky
www.facebook.com
Ok got it. Apparently they are releasing the 116T rated version of this tire in 275/60R20 this coming winter so I'll wait for those. Should be 5 to 10 lbs lighter.
1RMDave
23 Lightning XLT ER, 05 4Runner, 94 Miata
The fact that these have the 3 Peak Snow rating is laughable and just goes to show what a load of shit that rating is. Probably great for Arizona/Texas snow falls, otherwise it looks like another brodozer tread pattern with not enough sipes.
As one who lives in the snow belt but not where it gets bitterly cold (been there, done that), and having had "all season" tires that turned ro hockey pucks. I can say that it is still immensely valuable to know the tire will still function adequately in winter.
There is a difference between 3 peak and a dedicated winter.
