skotman01
USAS
Ford followed up, I've got it in my app now as well. That being said, the status isn't updating but I'll give it time and a better test later.
Monday morning I deleted the wife and my authorized drivers from Sync, hoping this would fix the problem after re-adding just me to the truck, that didn't work, so I accepted the situation as-is until after the start of the new year when I would experiment with a master reset of the truck & drivers, I'm hesitant to do that as it might cause issues with historic charging data, association of the FCSP, Connected Services and subscriptions, etc.
But I was going to try Ford Customer Service as a last ditch check of my Ford.Com profile to see if that could be the absolute root cause of the lack of visibility.
Lo & Behold, on the eve of Christmas Eve, I too have the PPO function showing on my Ford App at 1300 hours, it was not there this morning when I remote started the truck for morning errands.
With the truck on, then turning on the Frunk & Bed switches, I could also see the bar graphs for each inverter, I didn't test with a load, because I was heading out on a shopping mission.
I'm very happy to see this resolved with out having to go to extremes changing profiles, logins, and account settings.
Ford F-150 Lightning Ford app 6.3.0 update iOS & Android 1766517657263-1c
Ford F-150 Lightning Ford app 6.3.0 update iOS & Android 1766517693092-7i
The Weatherman
South Central KY
Showed up for me today and seems to connect and display correctly. ๐Ÿ‘
I had that screen and now it also shows a summary of the 2.4 kW inverter without having to click the right arrow to open (summary screen shows 2600W, detail screen 2400W ๐Ÿคทโ€โ™‚๏ธ ). What's weird is my truck is off and has been for a while, App was refreshed.
Ford F-150 Lightning Ford app 6.3.0 update iOS & Android 1766529039898-zk
Ford F-150 Lightning Ford app 6.3.0 update iOS & Android 1766529235717-h6
iOS version 6.3.0, not EA
frautumn
Fred
Northern CA
2022 Ford F-150 Lightning Lariat
ProPower is saving my ass as I type. Power has been out for 16 hours -- crazy wind and rain storms here in Northern California. The in-laws are here, we are able to have full house electricity (including hot water from the hot water heater) and Xmas Eve dinner celebration will go on as planned! I've been monitoring usage to make sure we don't break the bank.
Ford F-150 Lightning Ford app 6.3.0 update iOS & Android propower
skotman01
USAS
Specifically for backup power I created a home assistant dashboard to monitor power usage in my house in relation to the truck. This hopefully won't be used very often but it's good to have. Next step will be to upgrade my panel so I can put an interlock in.
Ford F-150 Lightning Ford app 6.3.0 update iOS & Android 1766766931269-7u
muels7
22 F150 Lightning Lariat
What integration gets the truck information like this?
