Charged to 344 miles?!
taraafico
ali
f150 Lightning
self
This is a mixture of hwy 60mph and local road driving.
Ford F-150 Lightning Charged to 344 miles?! IMG_0404
Joe Dablock
Joseph
Stewartstown Pa. 17363
Point is, if the last time you drove touched a lot of efficiency hot buttons, (low speed, ambient temp, stop and go driving, light on the accelerator) then the calculated miles at 100% charge will be higher. I recommend not taking the miles number too seriously, and only focus on the percentage. Once you start a trip, the remaining miles number will continue to adjust based on the efficiency hot buttons that change.
However over a period of time, if the miles number consistently decreases, then you may be experiencing some battery losses.
My Lightning at 63k miles is showing no loss, but my MME at 85k miles might be showing a 5% loss.
But both vehicles have exceeded my expectations. I honestly do not understand why these vehicles aren’t selling better than they are? Ford needs to advertise, advertise, advertise. When was the last time you saw Ford EV advertisement on TV?
SunPowered
Ben
2024 F-150 Lightning Flash
Recently charged my 2024 Flash (still the larger ER battery, not the down-sized Flash for '25) to 100% and found the GOM to read 334. This was surprisingly high, but also understandable, as the GOM extrapolated from a lot of local 35-45 mph driving at high efficiency. The 190 mile mixed driving round trip I charged up for, at 35 mph/ 45 mph/ 65 mph for most of it, left me with 140 miles still on the GOM upon returning home. So the GOM, surprisingly, was actually accurate with its prediction.
Whistler
2024 F150L
Here’s my ‘24 Lariat back in April when I actually shut the power down when parked throughout the day because the weather was perfect.
Here in Orlando/CFL there’s zero change in elevation, so good tire pressure and no jackrabbit traffic light starts gets you fantastic city range with an EV.
Now that it’s hotter than hell’s oven I just leave it powered up all day to keep the AC running, and the identical driving habits get me about 355ish on the same 95% charge.
Ford F-150 Lightning Charged to 344 miles?! IMG_0945
TobyB
Toby
Longmont CO
2025 Ford Lightning Pro
I drive in sport mode, spend a lot of time coasting in neutral and drive the speed limit. Mileage is calculated based on the last trip m/kwh data. I've driven EVs for 13 years and if you watch your consumption, you can get more efficient. As much fun as the awesome acceleration is, it obviously consumes much more energy than the typical ICE vehicle acceleration. Keep your center dash display on the trip data. We live in Colorado, so a trip up to the high country obviously consumes more, but regenerative breaking (especially in sport mode) really increases m/kwh.
Ford F-150 Lightning Charged to 344 miles?! Screenshot_20260812-065844
braking...
Modes don't increase efficiency, there is regen braking in all modes. I hope you're not saying you shift to N and coast...
blb228
Brett
2024 Flash Agate Black
Driving the speed limit is out of scope for me. But I am intrigued to hear about coasting in Neutral.
braking...
I find it difficult to believe one could achieve 3.0mpk without regen. Seems pretty safe to assume he means lifting off the go pedal.
Joe Dablock
Joseph
Shifting to neutral and coasting is counterproductive. Doing that eliminates the possibility of any brake regeneration. The only time I shift to neutral is to burn rust off the rotors, due to lack of use (regeneration braking).
jjupi91897
Joseph
My 80 % showed 335 this morning. But I know it's a result of driving locally only and being conservative on the pedals. But I'll take it.
....and ideal climate.
Shark150
Erik
Massachusetts
2024 F150 Lightning Flash
A few weeks ago before a longer day trip I was shocked to have 403 miles at 100%. Perfect weather and lots of city driving in my Flash with the 131kw battery. Didn’t last long at highway speeds 🤣.
F150guy
Garrett
2024 Lightning ER Lariat
I just charged to 100 percent and had a mileage range estimate of 460 miles! Again, it was based on slow, conservative local driving with temperatures around 70f. When I took the trip I needed to make for 200 miles on the highway my rate of usage was 2.3 m/kwh which means 300 miles max on my ER truck. Nowhere near 460.
Shark150
Erik
Massachusetts
Oh, I get it 😉 but still pretty wild to see those numbers. 460 is wild! Just imagine if manufacturers could find a way to make those numbers reality. 🤞 someday. For now my daily drives are a non issue even in winter with more highway.
CjPat
Carmen
Ford F150 Lightening Flash
I've seen drops in my range. I'm only getting 250 out of an 80% charge, I haven't charged to 100% in a while.
