2024 Flash Just over 3K and back in the shop again.
ackvor
Jake
Massachusetts
F150 Lightning Flash 2024
I want to love this truck so much. In the short time that I have actually had it in my possession, versus being in the shop, I have actually very much enjoyed it. I don’t think my problem is indicative of reliability issues, I think I just got a bad apple. The first issue was seemingly solved by replacing the drivers aside axle assembly and the wheel bearing/hub. This fixed the vibration/noise for 1 week. Then it was back to the shop for the same symptoms. Dealer is going to replace the wheel bearing assembly again, but said they don’t know what causing the bearings to fail. My limited knowledge of bearings makes me think there is something out of plumb and the alignment of the axle through the hub is off. I’m guessing this will be a recurring issue through the life of the truck. I’m nearing the buy back window and I’m hoping Ford will end this sooner rather than later. Just venting. Thanks.
Sounds like it could be a manufacturing issue if two assemblies both had the issue, a bad run on the assembly line that produced defective parts. If the third one has the same issue, Ford better look into that possibility.
Hopefully not a design issue like I experienced with Dodge/Chrysler transmissions in the 1980's and 1990's - had to change the automatic transmission fluid every 15k miles or else, dang it!
calandryll
Delaware
2024 Lariat ER
Well I had to replace the wheel hub on my 2024 Lariat on the driver side last week. Thankfully not the axle assembly, though I'm going to be weary going into the future.
ackvor
Jake
Massachusetts
Update: As I sort of expected, the second wheel bearing/hub assembly has failed. Same symptoms. This will be the third time to the shop for the same issue in less than 4,000 miles since new. This is beyond frustrating. Other than these issues, I love the truck, but I simply won’t be able to recommend this vehicle to anyone any longer based on the extreme frustration and inconvenience it has caused me.
You've got other issues if your truck is eating bearings like that. It's possible your garage is damaging them on install or its the wrong part. The odds of that many bearings being bad out of the box are almost nil.
ackvor
Jake
Massachusetts
Yup. That was my original thought too. Something is out of plumb and causing premature wear.
Does lemon conditions apply to this situation, multiple failures & repairs on same issue?
MountainAlive
Massachusetts, USA
Very frustrating. Although it might not seem like it, this could be an EV specific repair (due to how the drive axle connects directly from the EV motor) and you could reach out to the Ford BEV team for assistance. I can’t seem to find the contact info but I’m sure someone on here has it.
ackvor
Jake
Massachusetts
Update 5/30….truck back to shop this AM. I just received a call with the new diagnosis. Front drive unit has failed. It will be replaced. The part is 5 days out. I have submitted a buyback request as I believe I have met the threshold of my state’s laws ….we shall see. I actually just want a replacement. I love the truck and I know that sometimes you just get a bad apple. Hopefully @Ford Motor Company can make this right..
