evowner
Frank
SW Ohio
Retired EE
I tried to watch the video, but it will not load now, maybe too many viewers. My hope for the Lightning battery is that as new technology comes on line with longer ranges and lighter batteries, someone makes one for us that we can retrofit.
Grumpy2
Central Oregon Coast
23 F150 Pro SR
Retired Hvy Construction
I learned the location of the temperture sensors. They apparently harvest and sell used modules. I think I saw on the website their modules are not intended for use in vehicles. @MickeyAO already posted that removal/replacement of individual cells from Lightning modules are not easy.
https://www.f150lightningforum.com/...-conversation-with-chatgpt.21142/#post-416729
In the future shops like this will provide an alternate source of used modules, but determining real SOH of those will be the trick.
loschopper
los
US
23 F150 Lightning
Is the 2024 battery much different than 2023? Thanks
Reactions: GDN
Video loaded for me, but I'm not sure if these guys are just late to market and trying to make a name for themselves, or is he trying to really say that in 2024 Ford actually made these updates to the battery pack? I haven't been over to Monroe in a while, but they are usually very clear in their videos. They've got one of the first tear down videos.
Brons2
Mij
Cybersecurity
Greentec has a network of shops in areas where EVs are popular and do offer battery and module replacements for both EVs and hybrids. There is one in my area. https://www.greentecauto.com/locations
Their website does not say anything about the Lightning or Mach-E though, maybe too new to have used modules in wide circulation. They do have the Ford hybrids and the older Focus EV on their website.
The only modern full BEVs (I would define as 200+ mile range) they have replacement batteries on their site for is Tesla. A Model Y long range battery is listed at $9999 for example.
Brons2
Mij
Cybersecurity
From the looks of it, tech has changed and the 23 Lightning is SOL for a battery conversion.
What in particular has changed?
Icruz101
Isaac
Waco, TX
2023 F-150 Lightning
Looks like the battery cooling line connectors as well as the bus connections as far as I see. This from the Green tech auto video I saw.
CurtisW
Curtis
West Pittston PA
F150 lightning Lariat ER
Industrial Maintenance
I'm fairly certain very little has changed with the lightning battery from 22-24. Pretty sure you're mistaken on coolant connections being different. I've watched all the videos from munro and this greentec video and several others.
Here are the only changes I'm aware of. Copied from another members post from the service manual.
NOTE: High voltage battery trays built from 11-August-2023 are equipped with vent valves on the high voltage battery tray.
NOTE: High voltage battery trays built from 09-June-2023 are equipped with heat shields under the cold plates.
