Bed accessory slots
B177y
Bill
Olympic Peninsula, WA
Funny, the listing says that it won't fit my 2024 Lightning ?
That is absolutely what is in my bed. Maybe it won't fit because there's already one installed?
Actually, on closer inspection, the listing is different than what I have. Mine has a deeper rear wall and a square bottom, similar to this one listed for a Maverick:
Maverick storage
B177y
Bill
Must be for newer trucks. My 2022 Lariat doesn't have a spot for that.
Besides, $50 is a lot of money for very little storage space.
I agree. Funny that it was stock on my relatively "bare-bones" Pro and so far seems to only be in 2024's. The coiled recovery strap is about the only practical thing that fits, I just crammed in some other junk on top.
It does fit an old lithium motorcycle battery that I have lying around that is able to be used in any orientation. It fits perfectly if inserted sideways. I am going to use that as a rechargeable 12-volt battery to power some aftermarket bed lights that didn't come in my Pro, but it has cutouts with covers for the lights and switch.
Thunderand…
Thunderand…
Patrick
2025 Lightning Flash
FireFighter
Says it won’t fit my 2025 flash
B177y
Bill
I would take off the cover that you have and get some rough measurements of the space available behind there. My guess is that the listing from @SpaceEVDriver would fit, and the Maverick one that I linked would probably fit too, just verify the measurements first.
Thunderand…
Thunderand…
Patrick
FireFighter
Here’s the slot
Ford F-150 Lightning Bed accessory slots image
Athrun88
Toronto, Ontario, Canada
Looks like they deleted the little cubby. My 2024 Lariat ER has a little door where I keep a few items stashed.
B177y
Bill
2022, 2023, and 2025 Order Guides:
Ford F-150 Lightning Bed accessory slots 1747625243450-4c
2024 Order Guide
Ford F-150 Lightning Bed accessory slots 1747625303281-4q
So maybe 2024's only???
Timeless Epoch
Chad
2024 F150 Lightning Platinum
Professionally: Disaster Recovery - Recreationally: Watchmaker
Zekester
Zeke
2023 Mach-E, Awaiting delivery of 2025 F-150 Lightning, 2020 Jeep Wrangler
The correct part number for the Lighting is: RL3Z-60286A72-AB. This photo shows the stock (delivered) access panel for a 2025 (not sure whether it is a build one or build two) with the stock panel removed and the cubby with the part number listed above installed.
Ford F-150 Lightning Bed accessory slots 20250808_144521
The following photos are what the part looks like from a few different angles. Note that these were pulled from Ebay and may be for the ICE F-150 part, but the two are essentially the same.
Ford F-150 Lightning Bed accessory slots s-l140-1
Ford F-150 Lightning Bed accessory slots s-l140-2
Ford F-150 Lightning Bed accessory slots s-l140-3
I believe this replacement door panel available on Amazon, which provides s crude combination lock, will fit, but I've not tried it yet:
Security Lock Cover
The Bucking Rabbit (the folks in the video in the posts above) shelves will fit the Lightning version, I reached out to them and they verified that.
