- First Name
- CHRIS
- Dec 16, 2022
- alexandria virginia
- 2023 LIGHTNING PRO, 2012 Nissan Leaf, 2015 Toyota Prius, 2000 HD 883 Sportster
- Occupation
- Patent Atty / Electrical Engineer
I shared them in another post a while back, maybe in March 2025, not sure if I saved them on my PC, but I'll look.I have never heard of anyone being shocked by a dcfc but anything is possible. If you know of any links, I'd love to read.
One was a contractor working on a Tesla charger as I recall who didn't take adequate precautions to avoid electrocution....
Googled Tesla charger death and found these two, one is still not determined if the charger was involved, the second in Norfolk was the one I read about before:
31-year-old man was found dead inside a Tesla at a supercharger station in San Antonio, according to MySA. The cause of death is pending.
In an unrelated incident, a worker was killed at a Tesla Supercharger in Norfolk while doing installation work, and the cause of death is still under investigation, but may have been electrocution, according to WTKR
Details of the Norfolk incident:
- A worker was found dead at a Supercharger station during installation work.
- The cause of death is still under investigation, but police suspect electrocution.
- The Supercharger was scheduled to open the following day.
I think I found them after someone on another forum asked about the warning on the Tesla adapter insert about not using it when water or snow is present - here is a pic of the warning and if you got your adapter you can see it.
So I looked for any info about the possibility of injury or death from that scenario.
By the way, the Tesla mobile power charger apparently has a warning about rain:
"Warning: If rain falls during charging, do not allow rain water to run along the length of charge cable, causing the electrical outlet or charging port to..."
One study purportedly found that water incursion was possible with a CCS type 2 which could cause trouble including shorts and shocks, even “rapid unscheduled disassembly” of a plug...but we use type 1 though so maybe the problem is limited to type 2? Also that was in a Reddit post so I guess take it with a grain of salt since who knows if it is accurate or true, but FWIW it said:
I am working for a EV OEM and we have not had any cases och electric shocks on vehicles during charging during development. ( We started developing EVs in 2012).
We have however had cases of water intrusion in the charging plug (CCS type 2) causing shortcircuit and plug exploding which in its turn caused pieces of the plug flying.
Luckaly nobody got injured in these three instances since nobody stood near the charging vehicle.
Root cause for the fault is production faults in plug water proofing (different suppliers in all three cases).
It was also concluded that the CCS standard could be improved so that the PE pin is moved above DC pins so that the isolation measurement device in the EVSE could detect isolation drop due to water intrusion. Tesla standard and MCS already have that implemented.
Of course, if there is any malfunction in the DCFC equipment, given the high voltages and current, things could get ugly. Hopefully they are well maintained, But have to watch out in case they have been vandalized or damaged and avoid those that have (duh?).
L2 with 240V and up to 80A has to be treated with respect as well. Installation, damage to cords or wiring, damage to J1772 plugs, etc. all could lead to a shock.
There was one case I read about where someone had not fully seated the 240V dongle of a Ford Mobile Power Cord and got a mild shock from it. That could also lead to a fire from the higher resistance connection if the plug or socket pins become corroded, for example.
Not saying this happens a lot. Anything with electricity should be handled responsibly with due care, even a light bulb. Most of the time a 120V household shock won't kill you, but there are exceptions.
People smoke at gas stations and do other careless things with ICE vehicles, lawn mowers, bar-b-ques, as well.
Hope I didn't stir up a hornets nest here...time will tell.
