Deep Sleep Mode triggered at what cold temperature?
sdingeldein
Burlington, NC
Ford F150 Lightning
Physician
What year is your truck? There was CSP 23B70 to replace the BMS sensor on the 12V battery for some 2022 and 2023s. I get the messages much less frequently after they replaced that. Perhaps they did that CSP when it was in the shop?
I don't know. They said they did some CSPs and "flushed out the system" software wise (whatever that means).
mrau
23 Lariat⚡ER
Take a look at your BMS sensor on the 12v battery. It should have a date on it.
Can't recall the version # or the dates that were replaced, but if it is after October 2023 it should be good.
Ford F-150 Lightning Deep Sleep Mode triggered at what cold temperature? IMG_2507
It‘s not the date. If the Part number suffix is -AC or -AD, it must be replaced.
sdingeldein
Burlington, NC
Ford F150 Lightning
Physician
My truck was built in August/Sept 2023 and arrived in my town mid October.
mrau
23 Lariat⚡ER
You may be in the range. Best to check your BMS Sensor part number as @Maquis stated.
Here is a page from the recall notice.
Ford F-150 Lightning Deep Sleep Mode triggered at what cold temperature? Screenshot 2025-01-20 at 2.53.44 PM
davehu
hot springs, AR
It happens well before 9.5 volts. In my last event, it occurred at around 12.2 v and a SOC of 43% as measured through an independent monitor. On an AGM battery, 9.5volts is pretty much dead :sadface:
Seems to me that if your HVB is at 43% it should be charging the LVB to keep it at 12v. there shouldn't be a problem unless the HVB is near dead
Adventureboy
Ontario
It does. When the LVB SOC drops too low, it shuts off a bunch of modules including the modem to save power and then charges the LVB. It takes about an hour if uninterrupted.
Kansan
Wayne
2024 Flash
Civil Engineer
It turned fairly cold in NC 1 week ago with lows in the low 20s. A couple of mornings my car has not heated up (not plugged in) and my watch reports the vehicle is in deep sleep modes. I know from the Ford site that there are three things that will put it into deep sleep: not driving for 14 days, voltage issues, and cold/hot weather. My truck was in last week because of odd electrical issues but they just did CSPs and reset the system and it's been fine since then.
My question is this: how cold does it need to be to go into deep sleep mode? Also, when it is cold, if I plug it in at night will it heat up normally in the morning?
I just got back from an extended trip (18 days) during which I left my 24 Flash plugged in to a ChargePoint charger at the airport. The truck only has 2400 miles on it, but the 12V battery is reporting 350+ days in service. I have an ANCEL battery monitor installed, so I can see the LVB voltage during the entire trip. All accessories, other than the ANCEL, were disconnected. A few observations for the good of the cause:
- When the outside air temp (OAT) was below about 15F, the truck charged the 12v battery for about 14-15 minutes per session at 6-7 hour intervals. I'm assuming this was during events to warm the HVB. The colder the OAT the longer the warming event - some were 21 minutes when the OAT was below 0F. The 15-21 minute charge did not make up for the 20 minutes that the modules were awake after the warming event - on most warming events the LVB lost 0.02V or more.
- I was able to access the truck via Fordpass 4 days into the trip even though LVB was at 12.45V.
- I added 5% charge to the HVB at the end of 4 days and that brought the LVB to 12.83V.
- At 5 days without starting the truck, FordPass went into deep sleep mode with the LVB at 12.79V. OAT was 3F.
- Fordpass became connected again during events set up with Departure Times. I had a few departure times that I hadn't deleted, and I was able to access the truck via FordPass while the truck was preparing for departure. During those events I could manage the Target Charge, Departure Times, etc.
- During one of the departure preps 12 days into my trip, I bumped the target charge 5% and the LVB charge went from 12.43V to 12.90V. The higher voltage did not re-enable access via FordPass (I continued to have access only during departure prep).
- I was also able to access the truck via FordPass during the warming events. I caught it twice and was able to manage target charge, departure times, etc.
By comparison, my 23 Lariat 5.0 was sitting on a trickle charger in the garage and it went into deep sleep mode 14 days after it's last drive with the LVB sitting at 13.0V.
SMMD
SF Bay Area
F150 Lightning
Observation about Deep Sleep mode, not completely related to OP’s question about it being related to cold. Others have answered how deep sleep works, but I noticed something I haven’t seen addressed in the forum yet. I left my truck idle for over 90 days, not plugged in, while taking an extended trip. Somewhere between 14 days and 28 days idle, it went into deep sleep, as noted on FordPass. Following Ford’s recommendation for extended idle periods, I left it at 50% SOC. When I returned, it started right up, and the SOC was 49%. I was impressed that in 90 days, it only lost 1%. Deep Sleep Mode seems well designed, at least for long idle times in not frigid temps. The temperature was not very cold, probably in the 40s through the 60s the whole time.
Adventureboy
Ontario
Excellent info. Nice to know that Departure times light up the modem for FordPass. Once the truck drops the modem for power conservation, the only way that I know to reenable it back to normal operation is to actually start the truck (other than the temporary departure time observation). To add to this, if you are not bumping your SOC, the truck will charge the LVB from the HVB anyway, keeping the LVB alive.
Adventureboy
Ontario
Just curious what was the outside air temperature average when you did your trip? I'm tracking the impact of temperature on the LVB/HVB interactions.
I had a weak LVB on mine about a year into ownership. It was dropping into deep sleep after only a couple of days. I monitored the LVB on a passive independent monitor for a week and the truck charged the weak battery every few days from the HVB, keeping it alive even in deep sleep mode. No noticeable drop in HVB SOC for the week in comfortable weather.
I am hoping @Ford will adjust the charge profile to tolerate a longer duration before deep sleep. 14 days in your case is practical. I don't drive the truck every day but I still have to move it twice per day to driveway shuffle. In winter this means deep sleep in about 2-3 days for me on a healthy LVB and plugged in. The power cycle starts all modules up but the truck doesn't shut them down for about 1/2 hour after you shut the truck off and you end up with a lower LVB SOC than you started as @Kansan observed. No significant HVB charge cycles (and associated LVB charge cycles) other than a few short spikes to keep the HVB warm.
sdingeldein
Burlington, NC
Ford F150 Lightning
Physician
OK, took the vehicle to the dealer yesterday. End of the story, I hope. The LVB was "bad" when they tested it. Odd they didn't test it (hard to believe it wasn't bad a week ago when it was in for electrical error messages). It is working fine now and not in a deep sleep after a cold 20 degree (yeah, we are wusses in the mid-Atlantic) night.
Kansan
Wayne
2024 Flash
Civil Engineer
I just got back from a similar trip to the one I reported on last year - this time for 16 days. Same conditions as last year for both trucks; the Lightning was plugged in at the airport and the 5.0 was on a trickle charger in the garage. We had cold weather in KC and the truck was maintaining the HVB with grid power.
This year neither truck went into deep sleep mode. Last year the Lightning went into deep sleep mode at 5 days and the ICE truck at 14 days. I’m not sure which update deserves credit for the improvement. It was nice to be able to update my departure time in FordPass from the airplane as we got back to KC about a half hour early.
Adventureboy
Ontario
Yes, I've noticed deep sleep is far less frequent this year as well. It seems it recharges the 12v multiple times before going to Deep Sleep, where previously it would do it on the first low SOC event even while plugged in.
Nice step in the right direction.
davehu
hot springs, AR
I'm very frustrated with this deep sleep mode. my lariot has gone deep sleep multiple times in the past week. It's very cold and ice prevented me from driving for 5 days. It's been plugged into my FCSP all the time. Yet it's going in to deep sleep on consecutive nights even after I drove it. And the 12v was replaced in 6 weeks ago after similar issues in early December. At the time I took it in just because I had saw the "system off to save battery message" multiple times. This week I discovere the problem when twice I could initiate climate with Ford Pass. Wish I had documented it better but will be from now on.
