Default drive mode tow/haul?
hikinbengal
Bay Area, California
Lightning Lariat ER, Outback, Jeep TJ, Audi A3
Engineering Progam Manager
After latest software update, every time I start my truck is defaults to tow/haul mode. I looked at my settings and no active trailer is detected and I haven’t used this mode in months. Any suggestions? 2022 Lariat.
Manually select No Trailer.
ka-chow
Scott
2023 Lightning XLT
DJ
What's the 'latest' for you? Which version are you on? Since everyone seems to be different.
Altivec
I was having the opposite problem... Where I have a trailer attached and it defaults to normal mode if I miss the prompt (I found that ridiculous). It does this even thought it knows a trailer is connected and in the main computer. Ford better get their act together and stop trying to be too smart. How about leave the truck in the mode I left it in and be done with it. That worked for 100 years before we had these computers. Stop telling me what you think is best for me.
bg226
Bryan
Anaheim
I have the same issue. I haven't towed a trailer in 2 years. I went in and deleted the trailer I had in there and still have the problem.
itispete
2022 F150 Lightning Lariat
Same issue is showing up for me after 26.2.8.3. Oddly the update said "not successful" within the truck but the app reported successful. Sync has definately changed. I've removed all trailers, ensured that it is showing no active trailer, reset the APIM, and even pulled the negative 12v for 15 minutes. Still having the same issue. Noticed that the integrated trailer module recall update was available (ITRM-26.B04) but will not update (hangs on "preparing update").
The Weatherman
Dean
South Central KY
Try reattaching and selecting your trailer. Then deselect and remove it again. Alternatively, reattach, respect then detach and then select No Trailer Attached.
If anyone is seeing this situation currently, send a feedback report to via your SYNC screen at the time you experience the issue, this report will help the technical team and Dev's study what is happening.
itispete
Confirmed that this has to do with the APIM (SYNC-26.2.8.3 update). If you switch modes and do a APIM reset (track back and VOL-) the truck will go back into Tow/Haul. Has anyone performed FORSCAN changes experiences this issue (e.g. enabling side cameras when towing)?
