Electrify America Pass+
For those of you that have signed up for the Electrify America Pass+ for a month, then immediately cancelled so you only get charged for the one month, I have a couple of questions
Does the month start on the day that you signed up? If I sign up on the 20th does the membership rate last until the 20th of the next month?
Is the member rate reflected immediately or is there a lag between signing up and receiving the rate on your first charge?
It was immediately effective for me, I saw it reflected in the app within a minute or two. I canceled it a day later and it stayed effective as you think, to the next month same day (might've been day prior, can't remember now).
Thank you.
Nikos
Nicholas
Taylors SC
F 150 Lightning
Aircraft Mechanic
As soon as you see the $4 charge on your account, you will get the discount rate. Once they, EA, charges your credit card, then you are good for 30 days. Wait one more day at the end of the 30 days and they will charge you again $4. Hopefully you charge enough to see your $4 make a difference.
vandy1981
Tennessee
Plumber
You probably know this already, but don't forget to start the charge through the app before plugging in if you have plug and charge enabled. The EA Pass+ rates do not link with plug and charge.
astricklin
99 Mercury mountaineer
Typically a single charging session with the lightning will recoup the cost.
Nikos
Nicholas
Taylors SC
F 150 Lightning
Aircraft Mechanic
You are correct.
I get my $4 back every time I charge my Lightning on trips. What I don't like about EA is the slow rate charges and their broken stations. Waiting for the supercharger stations to come on line soon.
I have several trips across Michigan next month. Helping a kid move so I have some hauling miles ahead and will probably need to charge twice as much as usual.
I disabled plug and charge in FordPass. According to the EA app, I'm supposed to plug in first and then activate the charger. Is that wrong?
Nikos
Nicholas
Taylors SC
F 150 Lightning
Aircraft Mechanic
The $4 Pass+ will come handy. Don't know how EA is doing in MI. Be prepared to wait longer to charge. At least that is what I am going thru in SC.
Texas Dan
Daniel
I have had a EA Pass+ account pretty much as long as it has been available. I did cancel my Pass+ while I was waiting for my Lightning and was without an EV but reinstated it as soon as I figured out I couldn’t get the Pass+ discount through the Ford Pass app. I make enough long trips that the Pass+ pays for itself but I would hang onto Pass+ even though I may not plan on taking a long trip for a while.
For years EA has been the only choice if you are going on a long trip where you will need to CCS charge. I like the idea of giving EA a little money stream to help maintain the CCS chargers when I’m not using them. The $4 a month is hardly noticeable and I usually save many times that on a single long trip.
Texas Dan
Daniel
Neither Ford nor EA will tell you this but yes it’s wrong. Just activate the charger using the EA app using your Pass+ account BEFORE you plugin and the charger fires right up. Absolutely no need to cancel your Ford Pass Plug-n-Charge making it still available when you can’t get a cell phone signal.
vandy1981
Tennessee
Plumber
I have always had better luck activating the charger through the app (on the phone or android auto/carplay) before plugging in. Sometimes the handshake times out if it's plugged in too long before activation.
Also, if you're getting slower than expected charging (e.g. 30 kw or 50 kw at low state of charge) you can sometimes get faster charging by switching over to the other handle on the same unit.
Finally, if you get desperate you can sometimes activate a charger that shows dead/unavailable in the app using plug and charge.
Good luck!
Maxx
How does plug-n-charge works without a signal? I thought you still have to initiate the charge through Ford Pass?
I agree. Keeping EA alive now that Tesla is shooting for charging monopoly is very important. I would go for EA first if it is next to a supercharger. Unless EA failure rate get worse and completely frustrate me.
Texas Dan
Daniel
Nope, just plugin. The car communicates with the charger to tell charger exactly who you are. After that all you have to do is hit the “continue” button when the price window comes up on the charger.
