Ground Fault Test Failure Question (Frunk & Interior Outlets)
AntJohn73
Anthony
New Jersey
23 Lightning Lariat
I was messing with my pro power today and hit the ground fault test button on the center screen (touch pad). It told me there was a ground fault detected. However, the outlets do work fine. Anyone have the same issue? Do you think it is a software failure? Thank you
No, you're misunderstanding the test of the fault detection process ....... the warning is what you would see in an actual failure.
Hopefully the power was disabled after the test and prior to virtual reset.
AntJohn73
Anthony
New Jersey
23 Lightning Lariat
Duh! I guess I should have read the owner's manual more closely. My bad. Yes, that is exactly what they are doing. Thank you!
