Headlights Switching Itself Out of Auto Mode while on Bright and 'Bright-lighting' Oncoming Vehicles
Trav
F150 Lightning
2023 XLT LIGHTNING
Has anyone had the issue of your Auto headlight mode kicking itself into manual mode, and the issue causing you to bright-light on coming cars. When I catch the problem in time, I switch the bright lights off using manual mode using the manual stick. This is happening multiple times when I drive my vehicle at night.
What's the fix? How involved is the fix? It is an annoying problem. I hate the fact that I'm blinding oncoming cars at night. If this is a bigger problem than just me, why hasn't there been a recall?
Trav
F150 Lightning
Here is an update from searching for info about this problem from Grok-3. AI is so much better than a Google search.
RecommendationSince this is a known defect covered by warranty, take your 2023 Lightning XLT to a Ford dealer as soon as possible. Reference SSM 51058 and describe the exact symptoms: “Headlights in Auto mode fail to dim for oncoming cars, and the switch changes to On, requiring manual dimming.”
The switch replacement and BCM reprogramming should fully resolve it. For peace of mind, avoid driving at night with high beams until fixed to prevent blinding others. If you want to dig deeper or confirm settings yourself, check the F150LightningForum.com thread “Headlight Switch changing from Auto Mode to On” or search “2023 Lightning auto high beam issue” for owner tips and FORScan fixes. Let me know if you need help finding a dealer or interpreting FORScan data!
RocketGhost
Spencer
Memphis TN
2022 Lariat ER
It's the switch assembly. Mine has done it a couple times but not often enough for me to bother taking it in. There is a TSB for the Mach-E, I haven't seen one specifically mentioning the Lightning. The Mach E TSB said a trouble code would be stored, so that would help the service tech.
