Hit 183kW today at 57% SOC - SR 2023
WaterboyNorCal
Erik
NorCal
2023 Ford Lightning XLT SR
Nunya business ;)
It sure seems like Ford has updated the charging curve for the SR Lightnings again- a few months back I started to see the high 160’s and some low 170s and I was super happy with those numbers, since when I bought the truck, I would rarely see anything above 150kW.
Today I was charging at an EA 350kW station and was shocked to see 183kW peak- it only held 180kW for a few minutes, before starting to gradually drop down towards 120kW. Anyone else with a standard range see similar speeds recently?
Ford F-150 Lightning Hit 183kW today at 57% SOC - SR 2023 IMG_1145
Brons2
Mij
Cybersecurity
I just don't DC fast charge often enough to see any potential differences from the software updates in my SR. But I saw over 170Kwh multiple times at Tesla Superchargers when we took our road trip on Spring Break.
That was March and I haven't fast charged once since then.
On the Road with Ralph
Ralph
Mojave Desert, California
2023 Ford Lightning Pro
Real estate/biz consultant
I do a lot of long distance travel in my 2023 SR Pro - 13 trips of more than 1500 miles, approaching 300 DCFC charging sessions. I don’t closely monitor the peak charging speed (I just stick around long enough to confirm that it gets up over 120), but I know I’ve seen it reached 170+ on a few occasions. I am about to leave on trip 14 and will be using a couple EA hyperchargers along the way. With luck, they won’t be throttled for thermal reasons, and I’ll try to pay more attention to the peak rate.
Marc
Marc
Roswell
23 Lariat and a 24 Model X
insurance agent
I just did a long trip and I saw in the high 170's with my ER 23. I held above 150 to 70%soc.
Jim Lewis
San Antonio, TX
I would like to know if the higher charging rates lead to a faster decline in HVB SOH. Seems like Ford wouldn't have gone for it unless it had the mass data from all of us to know it's not going to make much of a difference.
WaterboyNorCal
WaterboyNorCal
Erik
NorCal
Nunya business ;)
Yes, I have wondered that also. My suspicion is the latter; although I think they were being very cautious with the initial DCFC charging curve, and I believe the data from tens of thousands of real-world DCFC charging sessions and the associated HVB health data is showing no significant difference, and therefore they are allowing for a less conservative approach going forward. Rivian has done this same thing recently with an updated charge curve - no manufacturer wants to have to replace a battery pack under warranty, but I think the data is clear based on Tesla’s long term data- DCFC does not have a meaningful impact on battery degradation with modern batteries due to more effective cooling systems and temperature monitoring via the BMS during charging. Battery age and overall climate (living in Phoenix vs. Seattle, for example), as well as total number of charging cycles, has a far greater impact on battery degradation.
I think it’s very likely that Ford’s cautious approach will result in relatively low battery degradation over time, primarily due to the large buffer, effectively preventing the user from letting the battery sit at 100% SOC.
tlink
Tim
2024 Lightning Lariat, 2005 F150 Lariat
I have gotten 190kW at a 350kW EVgo station. Actually it briefly hit 195kW but I wasn't fast enough with the camera to catch it.
Ford F-150 Lightning Hit 183kW today at 57% SOC - SR 2023 1750101022283-gr
FloridaMan655321
1973 F100, 2024 Flash
I’m on a 24 Flash, and so I’ve seen higher charge rates, but this is all good news for the 22/23 models.
I agree that this is probably for a longevity standpoint, and I’m glad for this. As Ford gets more data they should be able to dial in the charge rates.
Good info
PJnc284
Garner, NC
Ford's charge rate really isn't that high. It maxes out at only 1.2C and averages a bit under 1C which is rather conservative. 1C (meaning it takes 1 hour to go from 0-100% at that speed) is safe. The Taycan for example maxes at almost 3C which means it could charge 3 times at that rate.
Ford F-150 Lightning Hit 183kW today at 57% SOC - SR 2023 1750117094145-vs
Doctors Do Little
Randy
2023 F150 Lightning Lariat ER; 2023 Kia Telluride Prestige; 2021 Toyota Camry SE
physician
Good info
Best I saw on EA and EVGo last week was 187. I was so excited, and then blinked and it was at 96! Jeez
