Key vs laundry
rockhead
Glenn
BC
F150 Flash
Geek
WHOOPS ! Left key in my pocket, went through the washer and dryer :sadface:
I'll be damned, it still works !:like:
The face came off and one button fell out, all clicked back together and, did I mention, IT WORKS ?
#don'tTryThisAtHome
Scorpio3d
SS/IBA car wash owner
Sounds like you got lucky! Maybe you should go buy a lottery ticket or maybe you just used up all your luck?
RocketGhost
Spencer
Memphis TN
2022 Lariat ER
Since a new key is cheap and you can program it yourself if you have two working keys, I recommend getting a third now in case your washed key decides to quit working. If you only have one working key you have to have a dealer/locksmith program a new one.
Ricks Lightning
Los Angeles
Plumbing Contractor
You did better than I did.
As a plumber, I use these blue pills ? that contain a very potent dye. It dissolves in the water and you can trace it. Unfortunately I left 1 in my pocket and the wife did our shared laundry.
Her delicate unmetionables turned bright blue. My trousers ? already blue grew larger and a bit stiff ?
Ok sorry, forgot to check. Won't do that again. 2 weeks later, whoops I did it again.
Now I do my own laundry and stopped using the blue pills. I use food coloring instead. Green and blue are my go too Red and yellow, not so much except for Halloween and April 1st. In the toilet tanks.
Mach Turtle
Central California
2021 Mach E, 2024 XLT
Bum
I've heard from friends about dropping keyfobs from docks into ocean water, then having them recovered (by whoever is around with a wetsuit and mask) to find they still work.
I hereby do not volunteer to test this with my third fob (having done what @RocketGhost recommends) but someone, perhaps I, will no doubt do the test accidentally sometime.
