Lightning makes buzzing sound while charging.
ChrisCon
The Hamptons, NY
Just went outside to check on my truck something I’ve never noticed before was occurring .
The truck is making a somewhat hi pitched buzzing sound . Charging started 13 minutes ago and it’s the coldest night I’ve ever charged during . Is this the truck warming the batteries before charging commences ? Probably Noob question here , but I’m at 14,000 miles now and nothing like this before .
yes, there are Inverters, Chargers, and even battery Heaters/Coolers that may operate and make 'sounds' while charging... you are converting 240v A/C power into high-Voltage D/C power - which takes a lot of work : )
VTbuckeye
Joseph
Vermont
Mine sometimes makes a buzzing sound while charging, almost always while pro power on board is working and sometimes while driving. It sounds like the ballast of a fluorescent light fixture. I just want to know if this is normal, of if something needs to be fixed?
See response above your question.
VTbuckeye
Joseph
Vermont
That's what I was thinking, just wanted to make sure that all of these trucks buzz a little.
They make all sorts of noises while charging, and while cooling or heating the battery.
It makes a pedestrian noise at slower speeds. You can hear it inside if you try.
WHAT IS THE PEDESTRIAN ALERT SYSTEM
Due to the quiet operation of hybrid and
electric vehicles at low speeds, the system
creates a subtle sound to alert pedestrians.
The system is on when your vehicle is
running and not in park (P). Some sound
may be audible in the passenger
compartment.
VTbuckeye
Joseph
Vermont
compartment.
Not that sound. At normal driving speeds I have buzzing (usually once I have been driving for a few minutes). The buzzing is similar to the buzzing while charging/supplying 120V/240V power from the bed. I may need to drive another one to hear if mine is different. I have driven other EVs/plugins and the lightning is the only one that makes this sound. Our pedestrian sound is not bad and not particularly noticable. My humming ballast sound can be at any speed.
bewbie
NYC
I have a slight humming inside of my truck when I turn the ignition on. Does anyone else have this? Will post video in a bit.
bewbie
NYC
This is while sitting stationary, happens in P and D and while not hooked to a charger.
VTbuckeye
Joseph
Vermont
Mine sounds like a humming ballast in a fluorescent light.
VTbuckeye
Joseph
Vermont
I'm not sure...it does it a lot of the time, but not always. I noticed it the first time when using the outlets in the bed. It also does it sometimes when plugged in charging.
metroshot
Pat
Montclair, CA
2022 Lariat F150L + 2023 MME
Networking Tech
Yup, in hot weather, the fan kicks in very harshly.
In cooler weather, the fans don't spin, but there is a buzz.
