Many years ago, people compared mainframe computers via MIPS - Millions of Instructions Per Second. It was also called Meaningless Indicator of Performance...
Take how many miles per kWh you are achieving and multiply it by the size of your battery. If you have the 131 kWh battery, and your range is 369, you should be around 2.8kW/mile assuming the ER battery. That's pretty high - you're doing a lot of city driving.
Or, the range is reflecting your more recent driving. What does Trip 2 show if it hasn't been reset since purchase?
LightningShow
MA
'22 Lariat ER
Product Development
My app usually says 280-300 for 100% charge. Most of my recent driving has been highway. Probably >80% of all miles on the truck are highway because a large portion of the miles were from a road trip. My typical ratio is probably more like 60/40 hwy/city. Before I left on the 1600 mile roadtrip I had ~500 miles on the truck. Up to that point, my avg efficiency was 2.4mpk and the range at 100% charge said 321 miles. That's the highest I've seen.
gorwell
Sacramento
Ioniq 5 / XLT Standard
For Standard Range:
If charging to 100%, I'm getting EPA @ 230 with ~70% freeway driving at this point and in 100F heat, AC more than half of the time.
If all I did was drive in the morning @ 70F and no AC, I would probably see ~260 on a full charge.
I've been using ABRP to calibrate its Consumption, and right now I am at 2.27 @ 65mph.
Note my "freeway" driving is usually the speed of traffic, which can be anywhere between 40-80mph.
Typical Freeway drive (including getting on and off freeway)
Ford F-150 Lightning Lightning Real World Range -- What's Yours? 1662034509579
Efficiency for that drive:
Ford F-150 Lightning Lightning Real World Range -- What's Yours? 1662034781549
Keep in mind that the range shown is a guess. It uses recent driving history and predicts. If overnight the temp drops to 40 degrees, that number will drop. Then, if the temp rises during the day to 70, and you check again, it will go up.
Best estimate of range is knowing your miles per kWh, and the size of your battery. I get 2.9 - 3.0 miles per kWh driving 75 on the highway with my Mach-E. 91 x 3 = 273 in warm weather. In winter, take off 30 - 40%.
IF, on the other hand, I only drive locally, I will get much more range, but I really don't pay attention to that because I don't need it. I've seen 3.5 miles per kWh.
Right now, I'm testing "intelligent range" on my Mach-E. Car says 225 at 90%, i.e. 250 at 100%. As I've just shown, that's inaccurate.
Lightning math works the same.
jredondox
Jorge
San Diego, CA
2021 F150
i am at 280 or so 100% sometimes i get 300 if i go 60 on the freeway
Best estimate of range is knowing your miles per kWh, and the size of your battery. I get 2.9 - 3.0 miles per kWh driving 75 on the highway. 91 x 3 = 273 in warm weather. In winter, take off 30 - 40%.
I don't know about going 75 and getting 2.9... once these trucks go past 60-65 it drops to low 2ish
Sorry, forgot to mention that's with my Mach-E. Edited post.
LightningShow
MA
'22 Lariat ER
Product Development
I took a 175 mile round trip today to drop the stepkid off at college. I used 55% of the battery, my math says that's about 320 for the full battery. The trip was about half state hwy (45-60mph) and half divided highway (65-80mph). All of my experience with the truck tells me 320 miles is a reasonable estimate for range under good conditions.
Trick
NJ
4runner
Agree, please post your miles per kWh average.
Slohry
Scot
Riverside County, CA
2022 F-150 Lightning, 2021 Mach-E, 2019 Ford Fusio
Musician
Lariat w/extended battery.
It's been unseasonably warm here, (108° now) and I'm averaging 269 to 298 miles on 100% charge. My problem isn't the truck but keeping my foot out of it.
1,200 miles.... 1.3 towing 3.000lb camper, 2.6 truck alone
