Mike G
Mike G
N. AL, USA
OK...
So uninstalled everything and re-installed the latest FDRS. I do now get the login screen and login prompts. I added the trusted sites as well, in internet options.
So if I'm reading you correctly, I should be using the email address from motorcraft where I bought the license and that password, right?
Even though the FDRS login prompt looks exactly like the Ford OEM signin.
When I use the motorcraft email and password, I get "Do not recognize that email and password".
When you purchased the license they sent you an email right? It's that email address with whatever your password is that is the one they want.
If all else fails, Software Licensing Helpline at 1-800-768-8632
Mike G
Mike G
N. AL, USA
Oh my gosh, I got in....
But I had to sign in with my Ford OEM credentials and not the Motorcraft ones. The 2FA prompt actually went though this time and FDRS showed updating software...I am now at user settings and I can see the Measurement Toolbox in back.
What the?
Welcome to the wonderful world of FDRS.
It shouldn't give you any further issues logging in now going forward.
Mike G
Mike G
N. AL, USA
You did install the VCI manager right?
digitaldad
ABQ
'23 Lariat ER MaxTow
@Mike G replying to your last posts.
1. Yes, I received an email for the license purchase. The same email happens to be the same for both my ford and the motorcraft (but they have different passwords). The one that went through was my password for my Ford account and not the motorcraft one.
2. Yes, installed VCI right after FDRS and before attempting to log in.
3. Called 800-rotunda and very helpful soul extended my license by one day to help me out.
Mike G
Mike G
N. AL, USA
GWM, APIM, TCU, IPC first before updating anything else (all are USB-based updates).
Then PCM if it's in the list.
Cruise control related updates would be after powertrain, in this sequence if available; SCCM, CMR, IPMA/PSCM.
Everything else should be able to be done in whatever sequence you like.
digitaldad
ABQ
Thanks buddy. I have quite a few that rugedraw had given me before the CSP front sensor dealer visit updated. Though they didn't do the BCM for me (bummer).
For those of us who do these updates ourselves, I wanted to post this TSB here specifically as a kind of reference to use when trying to decide what modules to update in what order. It reinforces the sequence that's often been repeated here in this thread.
That TSB says it is recommended to use a 64gb flash drive, but a 32gb is said to be recommended by people here. Does it matter? I'm thinking of buying the equipment to do my own updates and want to get it right the first time.
21st Century Truck
Martin
In mu usage, either size should work.
FYI a portable SSD with a USB C dongle is significantly faster than a USB thumb drive. About $40 or so at MicroCenter.
Reactions: GDN
Mike G
Mike G
N. AL, USA
I really don't know why they say to use the 64GB since the largest APIM update I've ever seen was 15GB...but if that's what current guidance says ?‍♂
Sandisk changed their lineup sometime last year so the really fast USB drives (32 and 64GB) I bought years ago aren't available now. They're selling a drive in the same packaging but now it's 128GB and costs 31$ on Amazon.
I've taken a used 1TB NVMe drive I swapped for a larger size on a relative's computer, and put it into a USB enclosure and formatted it with a MBR partition and I've used that as well sometimes. Works great and NVMe drives are fast.
Mike G
Mike G
N. AL, USA
I want to re-emphasize though...if you do go with the NVMe drive in an enclosure...Windows sees that as a 'fixed' drive, not a USB drive.
USB drives are MBR partitioned by default, but 'fixed' drives are GPT partitioned and the vehicle won't recognize a GPT partitioned drive.
So make sure if you do go the NVMe route that you change the partition to MBR so that it will be recognized by the vehicle.
digitaldad
ABQ
I guess after the dealer did most of the heavy lifting with the front sensor CSP, these didn't take that long.
Only one USB update for me, GWM.
These three are the only left in the SW Updates list:
BCM - need dealer or OTA
RFA & ACM - upgraded but will not leave the list (I read to expect RFA but add ACM to my experience).
Kansan
Wayne
2024 Flash
Civil Engineer
GWM would be the one that may kick off more.
I’m sitting in my truck with the USB inserted waiting for a pop-up or some indication that the GWM update is happening. I formatted to exFat and think I’ve followed the process exactly. It’s been about 15 minutes with no indication that it’s recognized the USB. The truck is on and I have 15v. So now I have questions:
- Is there something I can do to determine if it’s working?
- How long do I wait?
- What’s my next step?
Thanks for any guidance you can give.
Ford F-150 Lightning Lightning Software Updates using FDRS IMG_9226
rugedraw
Javier
Miami
Auto Sales
When you inserted the USB, did you see "USB indexing" on the top left and then a message on your touchscreen saying "Do not remove USB blah blah blah"?
