Lightning_Bob
FL
Reserved Lightning...
This entire video is pretty fascinating - it takes a thorough full body scan of a stock F-150 scan and does aero analysis on what could be done to reduce drag/increase mpg - however this one section of the video stuck out as something that seems easily (but costly) way to net a 14.8% reduction in drag:
Not sure how one would properly calculate the impact on range for this type of bed cover....but if going by the video and assuming if one did all the mods (some of which ford has already done with the lighning - ie more aerodynamic wheels, smoother bottom) and netting 26% reduction in drag equated to 12% increase in range - doing this one thing of adding a slant/aero bed cover yields a 14.8% reduction in drag - this should yield a 6-7% increase in range...so an standard range battery would go from 230 miles to 245 miles, and the extended range would go from 320 miles to 340 miles...
This seems really tempting to try out until seeing there really is only one group manufacturing a slant/aero back for pickups, and it is pretty costly ($4,500):
https://www.mivehiclesolutions.com/products/aero-x-f-150
If anyone tries this out - please post your findings! ;-)
EVben
Ben
MN
Lightning, Ranger
Been thinking about this as well. I’m not super worried about range generally but that aside, it does seem like there is an avenue to make an aero Tonneau cover….
cyber tonneau for lighting
metroshot
Pat
Montclair, CA
2022 Lariat F150L + 2023 MME
Networking Tech
Yes, I loved that video!
Some practical info for sure.
But to gain 14% less drag after a $4500 bed cover seems a bit much for me.
I'd rather get a plain flat bed tonneau cover for $600 and be done.
DHK
Syracuse, NY
2022 F150L Lariat SR
gorwell
Sacramento
Ioniq 5 / XLT Standard
It would seem that a regular tonneau cover would accomplish a lot by itself. Here's something that says it's close to 6%.
https://www.agricover.com/downloads/pdf/2007_windtunnel.pdf
It's pretty mixed for tonneau cover helping. Mythbusters did a test and found it made no difference. Consumer Reports did a test and they found it made things worse.
The test above is from 2007; there's been 3 generations of F150s since then, each with an aero improvement.
F150s are designed to be as aero as possible and the current design has their air flow (as much as possible) run over the bed and touch down on the the tailgate.
The Ford rep does say the tonneau is better, but the way the tailgate is designed makes it not that much of an improvement.
LightningShow
MA
'22 Lariat ER
Product Development
Cool video. Nice to hear directly from the source that they’ve tested it in the wind tunnel.
Now i want to know how much improvement for folding the mirrors in. :)
Mr. Flibble
George
Seattle Suburbs
1995 Delica L400, Kia Soul EV, Jeep Diesel
Computer Nerd
I want to see mirrors just die, and be replaced with cameras:
Ford F-150 Lightning Lowering drag coefficient by 14.8%? download
LightningMcqueen
Justin
Austin,tx
2017 F150, 2021 Bronco Sport
I think the AeroCap will only make a difference at speeds > 50mph. range isn't 320 for highway.
I will be transferring my bakflip from a 2017 F-150 to the lightning. I am tempted to experiment with a cheap DIY aero top that could velco on top of the bakflip and use corrugated plastic sheets and angle brackets from home depot.
would be useful only for long distance trips.
kinda like the aero tricks they do for semi trucks.
Lightninorian
Damon
CA
Rapid Red Pro
Firefighter
Just make sure I'm not behind you on the highway.
PV2EV
There may be a new market for front popup tonneau covers ;)
bboy_72
Bob
Denver
F150 Lightning
Does anyone know what cap’s do for aerodynamics? I have an ARE currently on a power boost that I was going to use.
Easycamper
Dylan
2015 F-150 XLT 5.0L, 2018 PacHy, 2013 Volt
Would be nice to see a plot of miles/kWh at different speeds.
blpublic
Missouri
2016 F150 XLT
On my current 2017 F-150 XLT v8, when I added the cap/topper, it improved my average highway mileage by about 2mpg.
Hopefully, I will be able to do a more scientific test with the Lightning at different speeds and maybe different conditions.
