Mileage understanding
dohara0925
Dan O'Hara
Napa
F150 Lightning
Hey all,
I've read some of the threads on mileage and things are not to clear, so need some simple clarity. Purchased my 2024 Platinum in September. My understanding is that I should be getting 300 miles (or a few more) on a 100% charge. BUT.... When I charge my truck to 100% I have gotten 296, then 287, then 276 then 268. So my understanding is the computer is taking into account some other variables to give me my estimated mileage. I don't give a care about that, I want to know that regardless of what it says I will get 300 miles on my 100% charge?
Why doesn't the computer give you the estimated mileage on 100% period and then another screen or another setting give you the estimated mileage with all the variables?
Experience with my truck is you can expect a 30-40% difference in the guess o meter vs the real world. Use the heater and expect a 50% decline in range. The biggest disappointment in this truck is the actual range.
It’s only a disappointment if your original expectations were unrealistic.
FirstF150InCasco
Boston MA
F150 Lightning
Right,
Lets assume I am driving perfectly per the manual and "I should" get 300 miles to 100%. I understand variable like speed and all the other stuff (that effects ICE cars to) and I'm not really talking about that.
My perdicted range on 100% charge the other day was 249 I think. OK. BUT regardless of what that says I should still get 300 miles on a 100% charge, correct? I really don't care about the predicted mileage based on .......
No. As others have said, you will not get 300 miles.
FirstF150InCasco
Boston MA
F150 Lightning
Lets use your analogy, and I'll use real world. I have a goldwing as my primary vehicle. It has a 6 gallon tank and I know I can get 40-45 miles to the gallon, I know because I have driven it to 240+ miles. This is my starting point. SO, I know I can always get 240 miles on a full tank.
So every time I top my tank off I will get 240 miles. Now that is effected by rain, wind, co-rider, trailer, etc. (within that 240 miles), But lets assume I am by myself, when I top my tank off again, I know I can get 240 miles.
This is my point, everytime I top my tank off my starting point is always 240 miles.
But for some reason the computer in my truck is telling me everytime I top my battery off to 100% I will NOT get 300 miles I will get a different value each time and each time it is always lower. I want to know if 300 miles like Ford and the EPA is my 100% starting point
When I got my truck in September I got 299 miles to a 100% charge and now I get 249 miles to a charge, I don't want a average of my driving habits, I want to know what estimated mileage will be on a 100% charge each time I top off the battery. That is my point.
Why are you in denial mode? Clearly, an EV is not for you.
Farafield
Kim
Vermont
Ford F150 Lightning Flash
I believe terrain makes a difference as well. If your trip is all up hill, one way vs. a round trip covering the same terrain each way vs an all downhill trip, your results will vary.
CavRider
Somewhere near Minneapolis
F-150 Lightning LER, Kia EV9, Ford Expedition XLT Max
Sorry for beating the horse, but as a fellow motorcycle enthusiast, Harley Davidson didn't promise me I could always get a specific range for the 6 gallons of gas when the tank is 100% full.
I ride in variable conditions, I stop for energy when its called for, not when the tank runs dry.
I used to have one of those! But mine was a '14. I swapped it out for a K-1600 a couple of years ago. Now my RH grip is no longer just a volume control. :)
Calvin H-C
Calvin
The GOM (Guess-o-meter) is designed to give you a rough idea of what range you have, it is no guarantee. It uses an algorithm that takes your recent energy consumption history, with a heavier weighting on the most recent history, to come up with a somewhat educated guess of what sort of range you could expect, assuming that driving conditions and habits remain pretty much what they were the last time you drove the vehicle.
This is no different than how it works with a gas vehicle, but the variances are less noticeable for a number of reasons, not the least of which is the fact that an internal combustion is, at best, about 30% efficient. Thus 70% of energy is lost pretty much equally every time the vehicle is driven, and the variances only affect 30% of the energy in the tank. With efficiencies in the 80-90% range for EVs, just about any change in the driving conditions will have an effect on range.
You could have driven much of the last 400 miles in super-ideal conditions, but if the last 40 miles of that was way below optimal, the estimated range after recharging will be based on most of the conditions going forward being more like those last 40 miles.
2023 F-150 Lightning Lariat
I think this paragraph is what is causing the confusion. If you are confident that you'll get 300 miles with 100%, regardless of any variables, why does it need to show on the screen? That's in the manual. The screen shows you the second option, the one with all the variables.
Right!
Just put a post-it note on the dash that says 100% charge is 300 miles. And then the dash can show how many miles you can actually go...
The worst part is that this is the exact reason the GOM is so bad. Too many come in and ask why their truck doesn't go 300 miles at 100% charge...
Fortunete11er
Dennis
2024 Lightning Platinum
You have a chart, great, I don't use a chart, I have a baseline of 240 miles on a 6 gallon tank. I developed the baseline from riding, I can get more I know that but I know when I fill my tank I am able to get 240 miles. Each time I fill my tank I have to assess do I have a trailer, 220 miles, do I have a co-rider, 240 miles, is it raining, am I in the mountains, etc. I understand variables when riding and you assess those on the ride. BUT my baseline is 240 miles on what I consider a normal day I will always get 240 miles on a tank.
But the computer on my truck doesn't have this, 299, 276, 246. etc. If I drive my truck for 1 block each day and at the end of the month it will say 100% fully charged your estimated drive will be 139 miles. Uh NO. thats a calculation based on my driving history, I don't care about that. I want a baseline so I know how far my charge will go. I thought my baseline would be 299 miles but I'm not sure.
I know about energy, fusion, kool-aid in your tank etc. I know about variables about driving in the city vs highway, rain, cold, trailer etc. But I am trying to get a baseline of what a 100% charge on a 131Kw battery pack should give me, EPA mileage says 300 and I KNOW thats not true but......
That IS how far you will go. How far you will actually go.
How far you can go IS determined by those things. That is what the truck will ACTUALLY do. Anything else is just a lie to make you feel better. Why do you want a number that isn't true?
The baseline is 300 miles. That is what the epa said. That IS the baseline. Now for You, driving your truck, in your conditions, at your speed, it's going to be different, and that is what it is showing you
luebri
Neenah, WI
Print, Cut, Paste over your Guess-O-Meter. Problem solved.
Ford F-150 Lightning Mileage understanding Screenshot 2024-12-27 at 10.24.16 AM
luebri
Neenah, WI
The reality of the situation is Ford has developed a method for displaying Range that they believe is best for the majority. You have already concluded you do not like it and that is your personal preference.
I personally dont like it either, I wish it only showed kWh remaining. Not SOC%. Not projected miles.
I also understand, Im in a nerdy minority and know its not likely I will get my preference of display, so I deal with it and enjoy my wonderful truck!
CavRider
For the life of me I cannot understand why you want such a seemingly (to me) useless number. But if you must then I will say that I have not seen anyone in any forum claim that range is reduced by more than half for any conditions other than towing. So just assume you are going to get 50% of the EPA tested "mileage", or 1.2 mi/kWh and with the magic math your baseline resides at (1.2m/kWh * 131 kWh) =157.2 m. There ya go, there's your baseline. Anything better is gravy!
Note: I am mighty impressed that this site performed that calc automatically for me when I typed the "=" sign. Some AI lurking back there?
