Reducing EVSE amperage
Lucasw
Lucas
West Des Moines
2023 Lightning
Dentist
Hello,
I tried finding the answer but have had no luck and hopefully it's an easy answer for one of the many knowledgeable peeps on this site.
I reduced my FCSP to charge at 60A through the FordPass app. The question I have is whether it is also necessary to remove the cover and turn the amperage dial down inside the unit itself? Does the physical dial set the max possible and then the app can find tune it?
Thanks for the advice
The hardware derate is to accommodate installation on a less than 100A circuit in a code-compliant manner.
It not required for casual charge rate adjustments. Removing the dozen or so torx head screws every time you want to adjust would be a real pain!
Lucasw
Lucasw
Lucas
West Des Moines
2023 Lightning
Dentist
Thanks, that's what I assumed. I'd not only remove the torx screws, but have to manipulate my Velcro that I "installed" to hold my cover on after I quickly broke the holding tabs on it ?.
Adventureboy
IMHO, this should be configurable on the truck itself. The truck should have a setting to allow you to adjust the maximum amperage it is asking for. This would work independently of the type of charger you have.
Hardware derating is needed on the EVSE only when it is installed in a lower capacity circuit than the equipment is capable of delivering to protect the wiring. Software derating is a user choice either with the FSCP or if, with an update, can be settable on the truck to accommodate more location options.
For example, if you have a Ford Mobile charger that draws 30 amps, you cannot use this charger on a 30 amp circuit. If you could set the truck to ask for 24 amps, then you could. It would be a simple software limit setting on the onboard charger.
Hope Ford is watching this one.
Lytning
Georgia
I manually set mine in the FCSP. I trust a hardware setting much more than a software setting. And, we all know the deficiencies of Ford's software capabilities. I am powering it though a NEMA 14-50 receptacle. I initially set it at 40 amps (80% of 50), but the circuit breaker was getting warmer than I liked. I reset it to 32 amps, and all is fine. I have plenty of time for charging, so the lower rate is not an issue. Plus, a slower charge rate should be better for the HV battery.
Reactions: chl
