Tomwilli2025
According to the Installation Specs on the Ford Charge Station Pro, the charge rate can be decreased to work with existing circuit breaker panels via hardware settings. Has anyone learned what amperage it can be downgrade to? I have enough room to add a 70-amp breaker to my panel, so I’d like to be able to charge at 56 amps. I know I could add a 60-amp breaker and get 48 amps and that 48 amps would probably be supported. But what about 56 amps? My thinking is that since 4 AWG wire is recommended for both 60-amps and 70-amps breakers, I like the additional 8 amps charging capability.
https://www.globalowneraem.ford.com...us/documents/Lightning-FCSP-Install-Specs.pdf
