Platform to level rear floor with storage folded
PV2EV
Does anyone make a insert/platform to level the rear floor when the underseat storage is folded down?
Need to place dog crates on it, and don't want them flopping around.
SmoothJ
New Jersey
2022 F150 Lightning
Its not that much offset and should not cause them to flop around much. If you are concerned though, I believe there are small mount point on either inside of the rear cab (near the seat belts) to "strap" something in.
beatle
Springfield, VA
Perhaps shim the crates themselves to level them with the folded storage area?
PV2EV
PV2EV
Strapping them is a great suggestion, but would still like to have them sit level to take pressure off the crate. Transporting our champion Shelties, we want them happy and safe.
Maybe two mats...
Ford F-150 Lightning Platform to level rear floor with storage folded 220630255
AB852
F150 Lightning
Just went through this exact scenario this weekend. It definitely causes the crate to be unstable. Probably going to have to DIY it until someone comes out with something. Strapping it down would maybe help, just not sure where/ how to strap it down.
jazzmanmonty
Lincoln Corsair
self employeed
You can use bungee cords and suspend the cages from the oh sh"t handles. It will create more of a suspended calming effect for the pets.
PV2EV
PV2EV
Thinking plywood insert if nothing else.
PV2EV
PV2EV
Sounds like a pukefest?
Tomwilli2025
Alabama
Sales
My guess is maybe 1 inch elavation change. Maybe use something like a foam stadium cushion type material. Just a thought.
jazzmanmonty
Lincoln Corsair
self employeed
Or go to Menards and get a sheet of rigid foam that should help as well
PV2EV
PV2EV
My guess is maybe 1 inch evaluation change. Maybe use something like a form stadium cushion type material. Just a thought.
Much easier to cut to fit, good suggestion, thanks!
