- First Name
- CHRIS
- Dec 16, 2022
- alexandria virginia
- 2023 F-150 LIGHTNING, 2012 Nissan Leaf, 2015 Toyota Prius, 2000 HD 883 Sportster
- Occupation
- Patent Atty / Electrical Engineer
Yes, when he said he disconnected the battery and the truck turned off, I wondered what wires he removed from the battery and why the DC-DC converter did not keep the truck powered with the wire or wires removed.Agreed with everything except grounding, I'd think the system remain grounded even without the battery. As far as the edit about the DCDC not able to handle spikes, it may be true, but I don't think its very likely since there really isn't that much 12v draw in the truck without accessories and it's not very spiky. What I do think is more probable is that the 12v BMS and/or DCDC converter detects no battery and halts but even that would make me ask more questions like why?
Maybe the load was too much for the DC-DC converter without the battery?
Or maybe somehow that disconnected the DC-DC converter when he disconnected the battery?
It would make sense that the DC-DC converter would be grounded with or without the battery connected to the system ground, so you are probably right, which means I guess the reason the truck turned off was the load was just too much for the DC-DC converter to carry.
The DC-DC converter and the battery (neg via the BMS sensor) would be in a parallel connection with the rest of the 12v system.
But I thought, maybe where the negative is connected to the BMS sensor is a junction point where the DC-DC-converter is connected to a separate wire that goes to the truck ground, and that might have been disconnected when disconnecting the battery.
From the outside it looks like one big wire and connector to the BMS sensor but I haven't removed it to be sure.
Without wiring diagrams or dissecting it myself, a lot of guess work.
