Propulsion sound?
Kyler721
Kyle
2023 F-150 Lightning
Cyber Security
In the ACM module there’s something called “engine sound enhancement”. I tried to enable it via easy mode but it says “writing blocks failed - incompatible configuration”.
Kyler721
Kyle
Cyber Security
There’s also a “software engineer sound enhancement (ese) that you can enable via easy mode but it doesn’t change the fact the propulsion sounds toggle doesn’t stay enabled.
rugedraw
Javier
Miami
Auto Sales
Unless there is some hardware missing from the lower trims that is needed for this to work? I'm not sure, tbh. I looked through the ACM and DSP settings to see if I found anything in there that was related, but nothing.
Kyler721
Kyle
Cyber Security
In FDRS under “Programable features” there’s something called Sound System Upgrade. Could that help? Has anyone done this?
EDIT: There’s also “Enable Engine Sound Enhancement and Active Noise Control” in FDRS. I’m wondering if that’s it? It would program the ACM module.
Kyler721
Kyle
Cyber Security
Just tried it. Says “feature not supported”. To me that sounds like a piece of hardware is missing.
astrand1
Alex
Studio truck driver
Turning off the pedestrian warning sound is such a bad idea; and possibly illegal. It definitely is in Canada. Turning off the frunk one for makes sense, and I wish the backup one was quieter but I do understand why it is there.
Ahh. I don’t care. You know how many years hybrids didn’t make any noise. And how quiet gas cars today. Not to mention brand new teslas make zero noise going forward. Only in reverse. So I’m loosing zero sleep on this issue.
astrand1
Alex
Studio truck driver
I’m only talking about the in cabin population sound that makes it sound like an engine when you accelerate.
I wonder what setting was changed I. Your truck. Mine has made zero noise inside since day one. The mach-e makes noise but not the lightning. I’ve been in 2 others that are also quiet. ?
MountainAlive
Massachusetts, USA
There’s always aftermarket propulsion sounds you can add to you Lightning, such as this thing which connects to the OBD port https://glydsphere.com/ but I get the sense this isn’t for most of the Lightning crowd here :)
Kyler721
Kyle
Cyber Security
As far as I’ve seen it’s an option only platinums have. I’d be curious to see what settings are different compared to a lariat.
astrand1
Alex
Studio truck driver
I have a high option lariat and no sound. I have not been in a platty yet.
astrand1
Alex
Studio truck driver
astrand1
Alex
Studio truck driver
IIRC we discussed this on another thread (couldn't find .... I didn't make a strong effort) but I think the "sound file" is also needed on the appropriate module which controls the "in cabin sound effect"
