Rattle Driving me Nuts!
PFree
Paul
Baton Rouge, La.
2023 F-150 Lighting
Business Owner
Not the sexiest post I know but I’ve got a rattle in my backseat of my 2023. Tried folding the seats up, down can’t find the source…driving me nuts. Anyone with something similar? Hate to waste my time at the dealership.
marc_hanna
Marc
Nova Scotia
'23 Lightning Lariat ER; '25 Tesla Model 3; '16 Porsche Macan S; '87 MB 560SL
The down side of EVs is that you hear every creak and rattle. Get someone else drive while you hunt it down. I had a rattle on my passenger side front door. It was coming from the triangular plastic molding by the mirror. Eventually it just went away, but it sure was irritating for 6 months.
Good luck tracking it down!
Reactions: chl
tommyb
Sonoma, CA
'23 F-150 Lightning Lariat
I had such a rattle too. In my case, it turned out to be the spare tire jack behind the rear passenger side seat. Even when stored properly there was still a little play in that set up, so I folded in an old towel back there to keep things from moving. Good luck...
Heliian
Seatbelts, Jack, floor panels, junk inside the door trays, junk under the seat.
Ry2023
Rick
Pa
2023 f150 lightning
Yes I also have a 2023 lariat and have the same problem….. tried everything , and can’t get it to stop…. I may try to see if the jack behind the p s rear seat may be loose …. But other than that….i don’t know
mr.Magoo
2022 Lariat ER, AMB
@TaxmanHog led me down the right (or wrong) path in a thread about while ago where he complained (rightfully so) about the rattling moon-roof.
I've had this weird rattling that sounds like you have something rolling around in the rear door pockets, especially going slowly over uneven surfaces, I just jotted it down to me leaving crap around until I cleaned it up and it was still there.
Opened/ closed the moon roof and the problem went away for a few weeks, rinse and repeat...
So - open your moon roof fully, close it, and see if it goes away.
Ry2023
Rick
Pa
2023 f150 lightning
@Taxmhog led me down the right (or wrong) path in a thread about whole ago where he complained (rightfully so) about the rattling moon-roof.
I've had this weird rattling that sounds like you have something rolling around in the rear door pockets, especially going slowly over uneven surfaces, I just jotted it down to me leaving ceap around until I cleaned it up and it was still there.
definitely worth a try! I’ll let you know
I've had rattles back again, I think some of my crap under the passenger seats has shifted again.
Also make sure all the locks are engaged if you have the foldable storage box under the bench seat.
Whammy Bar
Thread title made me think of this joke...
A pirate walks into a bar with a steering wheel sticking out the front of his pants
The bartender looks at him and asks, "Hey, you know you have a steering wheel sticking out of the front of your pants?"
Pirate looks at him and says, "Argh it's driving me nuts"
My truck rattles too... good luck with your hunt. Mine is somewhere between the passenger doors, headliner, and seatbelt area... or maybe under the seat...
Pottsie
Huntersville, NC
2023 F150 Lightning Platinum ER & 2006 F150 XLT with 275k miles on it
If it’s at the back seat pax side. See if it above the door. Behind the. Garment holder / light. Above the window along the ceiling pillar. Loose harness. Could be the issue to. Ford tried to tell me it was the seat belt…it wasn’t.
Lube the moonroof gaskets and it goes away for a longer period of time.
lightspeed
2023 Lightning Lariat ER
If you ruled out the other obvious things, it's very likely the moonroof back panel.
You can easily test if it's the moonroof by pushing up on it with your hand near the edges of the back glass panel.
Solution is to clean the crap out between the weather sealing and the body. Some people just spray a rubber-safe lubricant in there which is ok too.
Scorpio3d
SS/IBA car wash owner
Sometimes when I hear weird noises in my vehicle I just turn the radio up a little bit and problem solved!🤔
Reactions: chl
evowner
Frank
SW Ohio
Retired EE
In my case it was the $2.50 worth of quarters in the change holder on the dash. It was there, I thought I was supposed to use it. Now I am trying to figure out how to repurpose it for a phone holder.
jimfigler
Orchard park, NY
I had a noise that bugging me for weeks. Sound like spoon sliding along the edge of a bowl. It was 4 safety pins in a rear door storage compartment sliding back and forth.
