Slight Reduction In Acceleration. Has Anyone Else Experienced This Issue.
Yes, I have done the 12v 'reset'...... And sync reset every few weeks when it acts up-
It's not running the Normal map, as there is still a difference between Normal and Sport, Sport just doesn't feel as "aggressive" as before.
Maybe related? –Sometimes as of recent (1 in 4 times) whenever I first start the truck and drive, the only modes available are "Normal" - see attached. This persists generally between 60-90 seconds or so. Even after selecting Sport after all this, the truck often will 'fall out' of Sport Mode and I go back in an re-select, usually it persists this second time. Anyone else seeing this?
That display issue has happened in the past, it clears up in time.
blb228
Brett
2024 Flash Agate Black
Make any changes via forscan?
Negative, still don't have FORSCAN.......yet. Should I get it!?
Only mods I've done to the truck are a leer cap, stubby antenna and now tires because I blew threw the first set of Hankooks in under 10k miles-
