Snow Drive Mode Request
Willebrew
Will
Dallas Texas & Denver Colorado
Rivian R1T Pre-Order | Lightning Lariat ER Owner
Software Developer & CEO - ADAS research and development for fun
Winter isn’t too far away and I would love to see a snow mode that changes the tuning of the powertrain for snow and ice conditions. Surely I’m not the only one requesting this from Ford. If they change the steering, throttle mapping, one pedal driving intensity, traction management, etc. for snow and ice, that would be super helpful. Who else wants to see this come in a future update?
River Rat
Magnetewan River near Georgian Bay Ontario, Canada
2022 Mach E Ice Blue, 2023 Lightning Star White
Canadian here, I've been in Texas during an ice storm and snow and can say Texans have a problem. Also have a Mach e and a Lightning both with snows and I use one pedal. I worried and thought I would use whisper in the winter conditions but engage works well so no need for snow mode. you have that under your right foot eh! Great in winter conditions.
Willebrew
Willebrew
Will
I’ve been through a winter storm in my Lightning and yes, it handles the conditions very well, but it could be tuned better for icy conditions. It’s super fun to slide around but occasionally one pedal skids because it’s slowing down too quickly. Having those tweaks would boost my confidence a bit.
Normal, and don't use one pedal.
FirstF150InCasco
Boston MA
F150 Lightning
Why not just turn off one pedal mode?
Willebrew
Willebrew
Will
Sneakypetie78
Pete
Marina del Rey, CA
2013 F150 limited
General Contractor
If you start a slide in one pedal, does antlock kick in? Seems like it would almost have to... getting back on the gas would definitely be counter-intuitive if you started to slide.
If you start a slide in one pedal, does antlock kick in? Seems like it would almost have to... getting back on the gas would definitely be counter-intuitive if you starred to slide.
Yes, I’ve had ABS engage when using 1PD. It felt to me like regen shut off temporarily while ABS was doing it’s thing.
Willebrew
Willebrew
Will
Same, one pedal does work with ABS.
Sneakypetie78
Pete
Marina del Rey, CA
2013 F150 limited
General Contractor
Makes total sense.
Gives you another tidbit of appreciation for the amount of stiff going through the computer(s) at any one moment.
Wheels out of sync = slide
Shut off regen.
Start abs procedure
And then we get cranky when it's not delivered on time! ?
chillaban
2022 F-150 Lightning Lariat
Yes, same with light regen braking. But it's a little scary -- regen basically suddenly cuts off and then ABS starts doing its thing, which feels like an acceleration relative to what regen was doing before.
I would compare it to an ICE car if you unnecessarily jabbed the brake pedal hard on snow/ice. Yes ABS kicks in, but you also get a little bit of sliding compared to if you never broke traction to begin with. It's less desirable compared to carefully feathering the accelerator/brake to avoid traction loss in the first place.
GarageMahal
JT
2023 Lightning XLT SR - Iconic Silver
Data Wrangler
Personally I found that Lightning in normal mode without one pedal one to be a very capable vehicle in all types of winter weather. The extra weight makes a huge difference. One pedal drive in snow seems like cruise control on in snow.... very bad idea.
Willebrew
Willebrew
Will
Exactly, this is why it would be nice to have a snow & ice mode. I’m so used to one pedal that turning it off seems counterintuitive.
